Go Back   HeliFreak > Blogs > 4712
BlHeli Setup 4.1.0.0.
Posted 06-11-2012 at 04:49 PM by 4712
Updated 07-03-2012 at 04:56 PM by 4712
The most recent Revision of BlHeli Setup can be found here
Here is BlHeli Setup 4.1.0.0.
It supports flashing and setup with BlHeli >Rev 2.0
(for Silabs-ESC only) and contains Hex files of latest BlHeli Firmware Revision [2.4, 3.4, 4.0 and 4.1].
Supported ESC's:
DP_3A
Supermicro_3p5A
Turnigy6A
XP_3A
XP_7A
XP_12A
To do: save Motor KV /pole/Pinion info somewhere
Changes to 4.1.0.0:
Added BlHeli 4.1 Hex files.
Changes to 3.4.0.0:
Added BlHeli 4.0 Hex files, dropped 3.2 and 3.31.
Added support for higher Gain values in Rev 4.0
Changes to 3.3.1.0:
Added BlHeli 3.4 Hex files.
Changes to 3.3.0.0:
Added BlHeli 3.2 and 3.31 (fixed 3.3) Hex files.
Now user is asked after Flash to assign prior settings to the new firmware (only if EEprom Rev. is the same)
Changes to 3.2.0.0:
Added BlHeli 3.3 Hex files
Changes to 3.0.0.0:
Headspeed calculation integrated.
Some improvements
(Hints show longer, double click on Hex Item in list starts flashing)
Changes to 2.4.0.1
Early BETA 3.0.0.0 containing BlHeli 3.2 and 2.4 Hex files
Changes to 2.4.0.0
- presumably unflashed ESC's will now be erased before flashing
Changes to 2.2.0.1
- Now BlHeli Setup is an ALL-IN-ONE solution. It contains Hex files of latest BlHeli Firmware Revision
Changes to 2.2.0.0:
- less warning messages when flashing a n ESC for the first time.
Changes to 2.0.0.4:
- User message improvements when flashing hex files
- added feature to disable re-arming every motor start (valid for Rev >2.2)
Have fun
Click image for larger version
ID:	912   Click image for larger version
Views 1452 Comments 0
