Go Back   HeliFreak > Blogs > jolyboy
Flybarless Twinn Rexx
Posted 08-01-2012 at 07:00 AM by jolyboy
I'm now in the process of upgrading my twinn rexx to flybarless . Reasons for doing so are:
  1. Simplified set-up
  2. Mechanically better (less "slop")
  3. Lighter
  4. Better for use with autopilots in the future
  5. More crash resistent
  6. Ability to run an ultra-low headpeed for FPV flying (no flybar requiring inertia to operate)
I'll be running 2 x Tarot 450DFC heads, with one Tarot ZYX-S flybarless unit fed into a TH-2 tandem mixer. The tandem mixer settings will be the same as when I was running an FB system.
So far, I only have the heads and the electronics installed, but still need to perform the rest of the set-up process. The process will be as follows:
  1. Set servo arms at 90 degrees to shafts @ midstick
  2. Level both swashplates
  3. Set blade pitch to zero degrees @ midstick
  4. Perform initial Tarot ZYX-S setup process
  5. Reduce gain on elvator axis, then adjust static rotor pitch for balance between rotor's thrusts (no up/down pitch in hover)
  6. Complete final ZYX-S setup
Among the FBL upgrades, I'm also upgrading the M2 x 20 bolts going through the miter gears, as they have all turned into "S" shapes. Turns out they are under rated for my application. I'll be trying out some M2.5 x 20 bolts with shoulders (ie. not threaded the whole way along).
Another upgrade I'll be doing is the addition of 600 size landing gear. I currently use "doubled up" (two zip-tied together) 450 skids, which are too low to the ground. The new ones are much wider and higher and will allow for harder landings without damage to the battery.
Views 777 Comments 0
