Go Back   HeliFreak > Blogs > News to report from the United Kingdom!
Hi All,
The first thing i would like to say in my blog is a huge thank you to Will James, for permitting me to report on all the Helli news and activity from the UK.
I will try to get on and update the blog as often as i can or when something a "little special" pops out the wood work.
Ill be keeping you up to date with the UK competition scence throughout next year, as this is my first competitive year also so it should be an intereting ride.
I also plan to try to make most of the fun fly's and get some coverage of those but with so many now filling the UK calander its going to be a busy year.
Hope you enjoy.
Regards
Alex.
New 7.4V Hitec Servos, Set on its way full report soon!
Posted 12-22-2009 at 04:16 PM by lex7919
[/IMG]
These Hitec servos look stunning! and i know they will be every bit as good in the performance department, HUGE torque ill follow up with a flight report once i get acquainted.
The "Ultra Torque" HS-7950TH is designed to operate on a two cell LiPo Pack. Featuring our high resolution "G2" second generation programmable digital circuit and our indestructible Titanium gears, The HS-7950TH has the performance and durability you've come to expect from a Hitec servo. Other features in the HS-7050TH include a 7.4v optimized coreless motor, integrated heat sink case, and a top case with two hardened steel gear pins supported by axial brass bushing.
The HS-7950TG has been designed for the most demanding hobby applications including the largest aircraft and monster trucks. Featuring a titanic 403oz./in. of torque at 6.0 volts, while still maintaining a respectable 0.15 second transit time
[/IMG]
Hitec's fastest standard size servo the "Ultra Speed" HS-7940TH is designed to operate on a two cell LiPo Pack. Featuring our high resolution "G2" second generation programmable digital circuit and our indestructible Titanium gears, The HS-7940TH has the performance and durability you've come to expect from a Hitec servo. Other features in the HS-7040TH include a 7.4v optimized coreless motor, integrated heat sink case, and a top case with two hardened steel gear pins supported by axial brass bushing.
The HS-7940TH has been designed for applications where speed and response is demanded. Perfect for High Performance Nitro and Electric Helicopters, Aircraft, Cars, and Trucks. Featuring a blistering transit time of .07sec but still maintaining a respectable 183 in/oz of torque at 6.0 volts
Both Servos share.
Detailed Feature Descriptions
G2 Digital Circuit
Titanium Gear Train (MK first gear)
Ultra Performance Coreless Motor
Heatsink Case
(8) O-Rings for Water/Dust/Fuel protection
Dual Ball Bearing Supported Output Shaft
Programable Features Include:
  • Dead Band Width
  • Direction of Rotation
  • Speed of Rotation (slower)
  • End Points
  • Neutral Points
  • Fail Safe On/Off
  • Fail Safe Point
  • Resolution* (default is high resolution)
  • Overload Protection* (default is off)
*These features are only programable with the HFP-20, HPP-20 or HPP-21 programmers.
