HeliFreak
HeliFreak (http://www.helifreak.com/index.php)
-   BeastX FBL System (http://www.helifreak.com/forumdisplay.php?f=239)
-   -   anyone using Parma Tape? (http://www.helifreak.com/showthread.php?t=392031)
flyfishsick 03-05-2012 05:53 PM
anyone using Parma Tape? any good ?
thanks
newbheliusr 03-05-2012 06:16 PM
Parma tape is great. It's also known as 3m 4011 tape.
flyfishsick 03-05-2012 09:09 PM
thanks for the info! i have some Perma tape will give it a try. :peace
Scured 03-06-2012 08:56 AM
i use 2 layers of that 3m 4011 tape, works great..i had 1 layer at first and had a slight drift..2 layers fixed it
GravityJunkie 03-06-2012 11:01 AM
The 3M 4011 tape is a harder foam gray tape. The Parma tape, I believe, is a gel tape. This is 3M 4010 tape.
newbheliusr 03-06-2012 01:12 PM
You are correct. Parma is a gel tape. Thank you for straightening me out. 3m 4010.
flyfishsick 03-06-2012 10:30 PM
so the perma tap (gel) is no good? anyone try it?
newbheliusr 03-07-2012 01:55 AM
Parma is great. I use one layer on mine
sutty 03-07-2012 12:09 PM
If it is the same as 3M 4010, which is the gel version, then it will be excellent. I have a single layer of 4010 on all four of mine, and I just can't fault it. I've said it before, and I'll say it again, anything that needs sticking to my heli will be held down with 4010 from now on. Of course if it isn't the same as the 4010 then this might be a different story.
Cheers
Sutty
anmatheextreme 03-07-2012 04:48 PM
So is the 4010 the same as Align PU Gel, except that the PU is thicker?
GravityJunkie 03-07-2012 04:58 PM
I'm saying the 3M 4010 tape is the same as this:
http://www.amainhobbies.com/product_...Tape-1x36-Roll
If you find the 4010 at the hardware store, it's about the same price. But you get almost twice the amount.
