Old 03-20-2009, 09:13 PM   #1
f5air
Default 11T, 13T or 15T?
hi there guys, who has that setup??? should i stick with the 13T? or maybe the 11T will give me more punch.
Motor:
Align 430L 3550KV
Pinions on my hand:
11T, 13T, 15T
I have the 13T now on my motor and 35G ESC. My batteries are 2200 mah electrifly and 2250 mah rihno, both 25C.
Thanks!!
T-REX 500 ESP -- 510, 750 GYRO AND 520, T-REX 450X -- HS55, 401 GYRO - S9260, ALL METAL (R.I.P), COPTERX 450SE V2 CF -- HS65MG, 401 GYRO - S9260(SOLD), AEROWORKS EXTRA 300 50CC -- DLE55, 7955TH, FROMECO, EDGE 540 -- .81 ALFA, S3305,
f5air is offline        Reply With Quote
Old 03-20-2009, 11:06 PM   #2
helijack
Motor:
Align 430L 3550KV
Pinions on my hand:
11T, 13T, 15T
Thanks!!
This is my setup:
Motor - same as yours
ESC - same as yours
Batteries - 2200 mah Kongs @25C
Pinion - 11T (makes for a nice headspeed and keeps things stable for hovering and FF)
T-Rex 450 SE V1, HS65MG, 9650, 325 CF, AR6100, 2200 FlightMax, 430XL/BL35X, GY401 ...SOLD
T-Rex 500ESP...SOLD
DX7...Still for sale
M.A.A.C. 78596
Ex President - Calgary RC Heli Club
helijack is offline        Reply With Quote
Old 03-20-2009, 11:22 PM   #3
f5air
Originally Posted by diverjack View Post
This is my setup:
ESC - same as yours
nice!!! i have 11T on my tool box, right now im just hovering, making 8´s, etc, and want to start to make some circles, just to get more time on flights and stable heli...
Old 03-20-2009, 11:38 PM   #4
Jimbo45
I was wondering the same thing. I have the 430XL and 35X esc. I ordered a 12 tooth pinion, but am wondering now if I will have too much gear to be running the cheapo woodies!? Maybe I need to order an 11 tooth...
Spektrum DX7
-Honey Bee FP x 2
-Axe CPv3
-CopTrex 450 SEv2 -Align 430XL, 35X, CC 10A, HS-65MG, GY401, S9257, AR6100e, Zippy-H 2200mAh
Jimbo45 is offline        Reply With Quote
Old 03-20-2009, 11:44 PM   #5
ken22golf
What cheapo woodies are you talking about? Align pro woods and tech model wooden blades can handle the 12T fine. It's recommended to lose the woodies if you go 13T.
8S Trex 500 ESP, Jazz 55-10-32 / 3026-1000 (Neu 1706/2Y ordered), 3517 cyclics, Spartan w/ 3500G, 425D, 7C FASST
ken22golf is offline        Reply With Quote
Old 03-21-2009, 12:13 AM   #6
Jimbo45
For now, I am going to use the included Copterx baldes, and the three no name pairs that I got from helidirect. They are the exact same that came with the heli. I think the package advises not to go over 2400 RPM or so.
I will upgrade the blades in due time, but wanted to start with the cheapies, because I know I will trash them quickly, and I don't want to worry about breaking pricier ones in the beginning.
Spektrum DX7
-Honey Bee FP x 2
-Axe CPv3
Old 03-21-2009, 02:13 AM   #7
Pagoda
Motor:
Align 430L 3550KV
The 430L will consume a lot of amps with a 13T pinion, and shorten flight times.
The 430L will be quite warm at the end.
A 13T can possibly overload the Align 35G, also. And that, becomes a crash.
Be sure to use a pitch curve ~ 10% less than the throttle curve.
The Heli will be more stable.
Pagoda is offline        Reply With Quote
Old 03-21-2009, 11:13 AM   #8
f5air
Originally Posted by Pagoda View Post
Motor:
Align 430L 3550KV
i will try the 11T, sounds good!!!
Old 03-21-2009, 12:10 PM   #9
cat5
If you only learing, the 11t probably give you around 2600rpm ok for flying I guess and you will have more run time and cooler battery. The 13t will give you around 3200rpm which is nice for 3d but will run your battery hot and shorter run time. It all depends on what kind of flying you want to do. Of course, fly within the tolerance of your battery and electronics.
cat5 is offline        Reply With Quote
Old 03-21-2009, 12:52 PM   #10
-Gamah
what about the 430X 3550kV with 13T running flat 90 curve on woodies?
-Gamah is offline        Reply With Quote
Old 03-21-2009, 04:49 PM   #11
frankbma13
So, I am running the 13T pinon with the Align Pro Woodies on the 430L motor. I have not noticed any problems at all. Heli is very stable, probably due to high head speed. Should I consider changing to the 11T pinon that came in the kit until I am comfortable enough to get some carbon blades?
I've been addicted to lots of things... but this is, by far, my favorite!
AMA#910221
frankbma13 is offline        Reply With Quote
Old 03-21-2009, 05:02 PM   #12
f5air
well tested with the 11T, wow, i feel better hovering and the 8´s, def. i will keep it, to get more time too.
Old 03-21-2009, 05:32 PM   #13
Dufault
I might be missing something, but I thought when you decreased pinion size, your headspeed get slower making it less stable and quick? Wouldnt that mean that your heli would feel worse?
Dufault is offline        Reply With Quote
Old 03-21-2009, 05:37 PM   #14
f5air
mmm not sure but i think is like this:
"drive your car at 30 mhp and make some fast turns............then try it at 60mhp" You will see that the car will act with more sensitivity and fast due the high speed" lol or maybe im smoking too much
Old 03-21-2009, 10:08 PM   #15
anatoly
IMHO there is no need to do that. I was running the 13T with the 430L, 35G ESC, and Align Pro woodies for a couple hundred flights. The person I bought the heli from probably put a couple hundred flights on it before that. I did put the Align heat sink on the motor to keep the heat down, but otherwise had no problems with motor, ESC, or blades.
Trex 500ESP FBL/MicroBeast
anatoly is offline        Reply With Quote
Old 03-21-2009, 10:33 PM   #16
Rosebud6
If you want the HS and a comfortable flight, add expo to everything. I took some tips from some of the more advanced pilots. They run 13t with 30% expo. I gave it a try and it made a world of difference in my abilities. I had not considered going inverted as I felt like I didnt have enough control added 25% expo and 10 fligths later...my first inverted flight. It gave me alot more control over my flips as well.
TREX 500ESP,Scorp 1400/15t, ICE100, AR6200, 510, 3G + 520,EDGE FBL main
Coptex 450pro, Scorpion -8 w/13t, -8 CC45, AR6100, 65MG, GP8750 + 9257
Copterx Black Angel 450, Scorpion -8 w/13t, AR6100, 65MG, GY240, DS520
Rosebud6 is offline        Reply With Quote
Old 03-22-2009, 09:37 AM   #17
helijack
You're welcome. Glad ya like it.
T-Rex 500ESP...SOLD
M.A.A.C. 78596
Old 03-22-2009, 12:24 PM   #18
frankbma13
Good to hear. I like how it handles right now, dont want to change it. I have the heat sink on too, since day one, and I'm getting 7 minutes of run time with the batteries at 3.75 per cell afterwards. Works great for me! I don't fly in "idle up" yet which will be my concern when I am at 0 degrees and 90% in the future. Did you fly in idle up for those couple hundred flights? Or at least, a good bit of them?
AMA#910221
Old 03-22-2009, 07:29 PM   #19
f5air
well tested on the field today.11T gave me almost 10 min of flying!!!!, which is 3.5 mor than the 13T pinion, for me is amazing, cause i can practice the 8´s a lot.
