Go Back   HeliFreak > R/C Helicopters > Painting and Airbrushing Tips / Techniques
Painting and Airbrushing Tips / Techniques Painting and Airbrushing Tips / Techniques
Old 03-14-2010, 04:15 AM   #1
helicoblast
Default Clear coat for Prepainted fuselage?
Hi,
I've bought an HeliArtist fuse and I'm quite ready to put the heli in, but the fuse hasn't clear coat.
It's my first scale build, and it's also the first time I want to do some paint job.
I've a small airbrush and a water based clear coat.
Do I have to sand the fuse, even if there are some stickers on?
Please give me some tips...
Thanks!
JR's X9303
T-Rex 700E/Xperience3D Conversion - Scorpion 560 - DS 760
Hurricane 425 - Scorpion 1600 - DS 760
Angel EPP 3D plane
Duratrax DX450 Motorbike
helicoblast is offline        Reply With Quote
Old 03-15-2010, 09:36 AM   #2
fastone93
If the fuse was shipped as it is shown in the pic, then I wouldn't do anything to it at all. It is probably painted with a fuel proof flat paint and will be fine without any type of clear. If you have your heart set on clearing it anyway, you don't want to use water based clear. You need to use a good automotive grade 2 part clear so it will be fuel proof.
Brian
Trex 700 dfc (OS 105HZ-R, Hatori Pipe, MKS HBL950, Futaba CGY750, MKS HBL980, Rail Mains, Rail Tail Blades)
fastone93 is offline        Reply With Quote
Old 03-16-2010, 03:38 PM   #3
helicoblast
Hi Brian, thanks for your answer.
The fuse has not been shipped has shown on the picture, there are not the rivets and the paint is flat, and I have let some fingerprints with my dirty fingers... So I think that there is no fuelproof clear on the fuse.
Do you think that I can use the water based clear that I have?
JR's X9303
Angel EPP 3D plane
Old 03-17-2010, 07:20 AM   #4
fastone93
Waterbased clear will not withstand nitro (or anything else for that matter). I am guessing that you have something like auto air transparent base, which is a seal coat for fine artwork, not a protective coating against the elements. The only way to be sure that the paint is protected is to get a 2 part automotive grade clear coat.
Brian
Old 03-17-2010, 02:55 PM   #5
helicoblast
Ok, thanks for your answer, i'll buy it and do that.
JR's X9303
Angel EPP 3D plane
Old 03-27-2010, 12:33 AM   #6
helipainter
and to keep it that millitary look, get a can of flattening agent and ask the store for a recomended mix to get it flat, semi flat or what your after. If you don't and you put 2k clear, it will be glossy like a new car.
You will want to lightly scuff this with grey scotchbright before application and a clear adhesion promoter wouldn't hurt
US Drones
Aerial Media Pros
Ritewing
helipainter is offline        Reply With Quote
