Go Back   HeliFreak > R/C Helicopter Support > 600 Class Electric Helicopters > 600/600 PRO Aftermarket Upgrades and Mods
600/600 PRO Aftermarket Upgrades and Mods Align T-REX 600/600 PRO Aftermarket Upgrades and Mods Support
Old 08-11-2009, 11:57 AM   #1
KDE Direct
Default KDE Direct Precision Tail and Anti-Rotation Bracket Upgrades for 600 Series Helis
KDE Direct has just released the Performance Tail Upgrades for the Align 450, 500, 600, and 700 series helicopters, as well as the new Aluminum Anti-Rotation Bracket Upgrade and fully-loaded TREX 600 XKIT! The new performance tail upgrades offer superior tail control and precision for all flying styles, with a precise bore for the stock brass bushing and a new flanged, radial ball bearing supported tail grip.
The best part about the new upgrades: they are a simple retrofit for the stock Align parts. No need to purchase aftermarket tail grips, hubs, or other expensive items. Rather, these are a direct replacement of the stock plastic tail control links that are known to wear and generate slop in a matter of 10+ flights. Once you install the upgrades, you will notice an immediate reduction in slop and a truly locked-in tail for your gyro to take full advantage of. Add this to the accuracy of the new Aluminum Anti-Rotation Bracket (no more flex and resultant cyclic mixing issues), and you have the best performance setup possible on the TREX 600 series of helicopters.
Thanks to all for supporting the KDE Direct brand!
ID:	109953   Click image for larger version
ID:	109954   Click image for larger version
ID:	109955   Click image for larger version
ID:	109956   Click image for larger version
-- KDE Direct, Inc. --
KDE Direct is offline        Reply With Quote
Old 10-07-2010, 11:54 AM   #2
tribe3
I just purchased the V2 tail upgrade but the flanged bearing binds against the plastic tail grip. Is it only for metal tail grips? I tried using a tiny brass washer but then it loses alignment with the tail pitch
Srimok FAIFA x 2 - Logo Extreme 800 - Rush 750 - Trex 700 - Trex 600 - Stretched T600 to 700 test machine - Furion 450 x 2 (or 3). All Skookum or Vbar equipped
tribe3 is online now        Reply With Quote
