Go Back   HeliFreak > R/C Helicopter Support > Outrage Velocity 50 Nitro
Outrage Velocity 50 Nitro Outrage Velocity 50 Nitro Helicopter Factory Support Forum
Old 12-23-2010, 02:16 AM   #1
Butch B
Default Tail wag that i can't get rid off.
I can't seem to get rid of a vibration that is upsetting my spartan gyro and causing a tail wag. It doesn't seem to matter what gain i run, it's still the same.Any ideas?
Butch B is offline        Reply With Quote
Old 12-23-2010, 04:54 AM   #2
kazager
which Spartan?
which servo?
Picture of mounting might be helpful. From my experience I've had some that want the metal plate, others that don't. If everything else is good, I would experiment with mounting & tape.
kazager is offline        Reply With Quote
Old 12-23-2010, 08:22 AM   #3
RotaryBliss
A little more detail would help. Fresh build? Experienced heli? Was working fine? Never flown? Engine broke in? Which servo? Servo ball from center? Fast tail wag, slow tail wag? Radio set up right?
RC field rep.
Team Tail-in / Helifreak Elite Bacon Awareness Committee
RotaryBliss is offline        Reply With Quote
Old 12-23-2010, 12:41 PM   #4
Butch B
It is a spartan quark gyro with a outrage 9088 servo. It is top mounted, but have tried different locations with the same results.It is mounted as per spartan instructions with the steel plate. I am also running a dx8 with an ar7100r recevier.The helicopter has flown for about 10 months, it had been running well but started have tail problems about 1 month ago, but then had a crash so rebuilt. Replaced all the bearings,main shaft etc etc. but still have this problem.
Old 12-23-2010, 04:45 PM   #5
RotaryBliss
how long ago did you switch to the dx8. Would it happen to be about the same time the tail issues began a month ago?
RC field rep.
Old 12-23-2010, 06:37 PM   #6
Butch B
It probably would be.
Old 12-24-2010, 01:56 AM   #7
crashagain
I am running a spartan on mine with no metal plate, using the Zeal tape and a velcro strap. Tail is solid..
Titan X50...Trex 600LE... Trex600NP...Trex700...
more to come.....
crashagain is online now        Reply With Quote
Old 12-29-2010, 04:43 PM   #8
johnpotter82
Are you aware that the dx8 uses different gyro gain settings.
johnpotter82 is offline        Reply With Quote
Old 12-29-2010, 05:34 PM   #9
pugdavey
I have a spartan on mine with standard tape DS650 with no tail problems.
Have you checked the boom supports??? they can make the tail wag
7HV,EL Brute, HW120 hv, bls 451,251, SK540
Warp, mks92a, ds525,hw40pl, sk540
Lynx team pilot
pugdavey is online now        Reply With Quote
