Old 03-05-2011, 09:35 AM   #1
FurryTrex
Default DSM-X Rx & Sat not working with MB?
LHS sold me a DSMX Rx and Sat, he said it would work,and i am having problems initializing the Beast, it just sits there scolling the LEDs on the right hand side..
do these new DSM-X stuff work with the Beast X?
also i am using the dx6i..
My tutorials:
Trex 250 Carbon Fiber Tail Push Rod
http://www.helifreak.com/showthread.php?t=238095
FurryTrex is offline        Reply With Quote
Old 03-05-2011, 09:37 AM   #2
AnTi Taco
i hooked up my ar8000 with SAT thats dsmx and working perfect(dx8)
maybe the newer sats don't work with a dx6i but that shouldn't be cause it should just bind in dsm2
Compass 7HV 9180/9188 Vbar
Compass 6HV 9180/9188 Skookum,4025-630KV
Compass 6HV Savox/ 9188, Vbar,
Fusion 50 9080/9088 Beast X
Velocity 50n 9080/9088 VbarSAB Goblin 9180/9188 Kontronik helijive Coming soon
AnTi Taco is offline        Reply With Quote
Old 03-05-2011, 10:08 AM   #3
djamgils
are you using a dsmx sat only because that wont work with the MB I believe.
If you are using a regular RX then it doesnt matter on wich protocol the RX-TX works.
Just make sure you have selected the normal RX option in the MB
djamgils is offline        Reply With Quote
Old 03-06-2011, 04:31 AM   #4
FurryTrex
I have a DX6i TX and a DSM-X RX and DSM-X Sat.
can't get the BEAST X to get past the sensor check(the right hand bank of LEDs just scroll)
So from what I have read, the BEASTX doesn't work with DSMX yet? correct?
My tutorials:
Old 03-06-2011, 09:56 AM   #5
garyji
I don't think and older DX6i is DSMX compatible unless you send it in.
G.
T-450 Sport FBL, T-550 V1 FBL, T-600E Pro. Red Goblin 700. Tarot Pro 450 in a scale Hughes. Bunch of little Blades, and Planks. DX8, Full scale Jet Plank Driver.
garyji is offline        Reply With Quote
Old 03-06-2011, 03:48 PM   #6
JustPlaneChris
If you guys are using 'standard' receiver type, the Microbeast won't care if it is DSM, DSMX, Futaba, Hitec, etc. This "DSMX incompatibility" is only when using the satellite option.
-Chris
JustPlaneChris is online now        Reply With Quote
Old 03-07-2011, 01:58 AM   #7
djamgils
you are right. but the problem here seems to be that he is using dsmx receiver with a non-dsmx TX
Old 03-07-2011, 06:14 AM   #8
egicar
If there is a problem (correct binding?), it's not a Microbeast-related problem.
You don't have to enter in the Microbeast receiver menu, because you receiver is a "standard" one.
If you have selected (in the Microbeast rx menu) another type of rx, please go back to the default "standard" and exit this menu (it is only for "special" connections, like only satellite, S-BUS or PPM single line).
Ciao
Egidio
GAUI addict: EP100 PRO, EP100 V1, EP200 V2 BeastX/satellite, EP255 BeastX/satellite.
Now, TREX 250 SE BeastX/satellite as well.
egicar is offline        Reply With Quote
