Go Back   HeliFreak > R/C Helicopter Support > Compass Model Helicopters
Compass Model Helicopters Compass Model Helicopter Discussion
Old 04-05-2011, 08:04 AM   #1
eivus
Default 6HV stock motor & ICE HV settings
I bought a ice hv 120 and I would like to know that you have fully configured you in the cc.
eivus is offline        Reply With Quote
Old 04-05-2011, 03:21 PM   #2
P.I.Engineer
i'm still trying to figure out timing, my top of my motor is pretty hot on high timing, i'm gonna go back to mid and see how it is.
i should really just buy a hw
Protos 380
TX: Fr-Sky Taranis
P.I.Engineer is offline        Reply With Quote
Old 04-05-2011, 06:38 PM   #3
hornet dave
8khz pwm freq, i've tried both standard and low timing with good results. Haven't tried high timing.
hornet dave is offline        Reply With Quote
Old 04-06-2011, 03:00 AM   #4
Dflyer
Just try 18 of timing, gives the motor good power and the motor stays cool ! Works great
Grtz,
Dirk
The heli virus has infected me and i hope that there is NO CURE !! Compass Support Team
__________________________________________________ _____
Warp 360 / 6HVU / CY Stingray / Invertix 400 / SH Little Spyder
Dflyer is offline        Reply With Quote
Old 04-06-2011, 05:56 AM   #5
flybar-les
i'm flying in outrunner mode @ 18, if i switch to 8Khz will i have more power(hehehe) ?
SAB Goblin 630 12s Vbar
mCP-X + 130X + mCP-X brushless
DSX9
www.rs-modelstore.be follow us on facebook !
flybar-les is offline        Reply With Quote
Old 04-06-2011, 09:41 AM   #6
P.I.Engineer
should the pwm freq be at 12? is that what the hobbywing flies at?
Protos 380
TX: Fr-Sky Taranis
Old 04-06-2011, 09:58 AM   #7
flybar-les
i tried the CC on 12Khz, it made the tail go berserk...
DSX9
Old 04-06-2011, 01:07 PM   #8
P.I.Engineer
just flew 12khz and 19 timing, it felt like i had more power. 95% flat throttle curve.
I've been working on tic-tocs, and today i did a climbing tic-toc, so i'm guessing the power is up a bit.
I haven't checked my cell voltage yet.
Batteries were cooler, the top (silver part) of the motor is still pretty hot. I can keep my finger on it for a good 15 secs, the rest is cool.
I was flying 8khz and high(10) timing before.
all this is on a cc85hv esc.
Protos 380
TX: Fr-Sky Taranis
Old 04-06-2011, 05:11 PM   #9
eivus
Could you paste the complete settings of castlelink?
Old 04-06-2011, 05:40 PM   #10
P.I.Engineer
is there a way to export it?
Protos 380
TX: Fr-Sky Taranis
Old 04-06-2011, 05:43 PM   #11
eivus
yes, save settings and copy the contents of the text file it generates.
Old 04-07-2011, 11:18 AM   #12
Dflyer
here is a formula that will allow you to figure the PWM for the various motor.
Motor KV x Nominal Voltage Used x Motor Pole Count / 20
If you come up with a number in-between settings such as 9,235 you should
round down to 8k Low timing works well with these motors so you can start with that & check the temps. If there not bad you can move up to normal but do a short flight & check the temp. Timing that's to high will cause hi heat.
So for the 6HV this is as follows :
540 (kv) x 44.4 (NV) x 8 (poles) : 20 = 9.590 so pwm can be set to 8.
Hope this helps!
Grtz,
Dirk
Old 04-07-2011, 11:28 AM   #13
TheBum
+1. I get really good power out of the motor at 12KHz and 15 timing on the HW. Would it be better to run the HW at 8KHz? Which would run cooler?
HeliFreak Support
DT520Ev2 (VBar), Protos Max Evo 700 (Brain), Protos Max V2 770 (Brain2; under construction)
TheBum is online now        Reply With Quote
Old 04-10-2011, 09:07 PM   #14
P.I.Engineer
Hex55: 85
Brake Strength: 0
Brake Delay: .6 sec (Delayed) (*)
Brake Ramp: Immediate (*)
Cutoff Type: Soft Cutoff
Motor Start Power: 59
Direction: Forward (*)
PWM Rate: 12 Khz (*)
VehicleType: Helicopter
ThrottleType: Fixed-Endpoints
Throttle Response: 5
Governor Gain: 50
Initial Spool-Up Rate: 5
Head Speed Change Rate: 5
AutoRotationEnabled: False
GovernorType: Simple
Current Limiting: Normal (*)
Cutoff Voltage: Auto Li-Po (*)
Motor Timing: 19
Power-On Beep: Enabled (*)
Auto-Lipo Volts/Cell: 3.2 Volts/Cell
Protos 380
TX: Fr-Sky Taranis
