Go Back   HeliFreak > R/C Helicopter Support > Outrage RC > Outrage G5
Outrage G5 Outrage G5 Helicopter Factory Support Forum
Old 08-25-2010, 02:12 PM   #101
scnsaracer
Thanks for the tip. I will give that a try.
Originally Posted by HFG View Post
The loose grips is usually caused by the inner radial bearing in the grips moving, try loctiting it to the grip.
AMA 125054
Rave ENV
Total G
scnsaracer is offline        Reply With Quote
Old 08-25-2010, 07:11 PM   #102
s0laris
The loose grips I have too. But Heli flies fantastic. I tried loktite
No appreciable difference in performance noted
Outrage 550, Goblin 630, 700, warp 360, Dual BL Mcpx, 130x
**When you start to be in complete control reflexes are not a requirement.**
s0laris is offline        Reply With Quote
Old 07-18-2011, 06:50 PM   #103
<3My480Pro
Default :)
Just received my brand new G5 and notice a few things needed modding. On the rear belt shaft I notice that you needed to use high strength thread lock to keep the shaft in place. So instead of using loctite, I drilled and threaded the center of the shaft to use a M2x3mm screw to keep it in place instead.
<3My480Pro is offline        Reply With Quote
