| Atom 500 Compass Atom 500 Model Helicopter Discussion |
What choices of blades do I have for a 5.5 a part from the
the stock ones which are 515mm,
We do accept FB parts for Compass 5.5 To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
I am using SAB 473's right now.
There's also Edge 475's at ReadyHeli |
#3 |
Thanks,
And forgot to mention, I got paddles, Readyheli's out of 475's (FBL) For now, can't find a SAB dealer for 473's Can I use FBL blades on a FB heli ?
#4 |
Yes, if you are just hovering around. They should make the heli more stable. I don't recommend for 3D.
6HV|Warp 360| Compass Models | Prostar Hobby | MKS | EP Buddy | Team KBDD |
#5 |
Ok, I'll stick to FB blades then. Not that I'm doing any 3D but
I just don't hover around anymore. This hobby is getting sophiticated. I think I'm gonna stick with stock 5.5 blades, its simpler.
#6 |
Stock blades are nice and nothing.else in that size has thes same 11mm root.
#7 |
That,s the size of the root I have to look for, 11mm ?
I saw some Edge blades FBL 473mm with 10mm root = $59.99 For FF flight, figure 8's for now that's about all I fly. And for Sab from 430mm to 550mm nothing in between. If ever, which one 430 or 550.
We do accept FB parts for Compass 5.5 To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Last edited by sly the dogman; 07-24-2011 at 04:31 PM.. |
#8 |
You're not going to find 11mm root blades. Should be 10mm roots. Your grips will vary, but the size is 10mm.
So far I really like the SAB's. They are definitely quicker on cyclic than the 5.5 520's, but of course have less collective authority--having a narrower chord and being shorter. They are very, very stiff and have a nice finish. |
#9 |
Hence the spacers, my bad.
#10 |
It's weird that the Compass grips are never 10mm. They are always too wide to use without spacers. And I've found that most spacers are about 1mm thick, too, so you have to either use only 1 spacer or make your own thinner ones.
But it works... |
#11 |
I dont know about availability in the US but I have just learnt that spin blades do a 515mm blade with a 10mm root
http://www.spinblades.com/index.php?...&product_id=76 Ive always been put off stretching my atom due to the compass blades being all black (I dont like black blades lol) but I might have to give this some more thought if I can get these blades easily
Velocity 50 (w/ Rossi R57) | Atom 500 | T Rex 450V2/Sport Hybrid |
#12 |
That is good news. I'm sure that if SB finds a US distributor, that these blades will be made available.
Looks like they may be available in Canada, they have a distributor in QC.
#13 |
I looked it up, NDheli not far from my home. Can't find
515mm thought and not cheap either. For now I'll go with the stock black ones.
#14 |
Other blade options would be nice, thankfully the stock 515mm blades are really nice.
Chris D. |
