| MA Whiplash Miniature Aircraft Whiplash Helicopter Support Forum |
I am waiting to here from guys who have recieved theres. There builds and the equipment used. Plus flight reviews. Mine still sits idle as a newbie flying my 450.
Mine is on the brown truck, arriving Friday.
Equipment will be: Futaba 14MZ (or 8FG if I feel like programming it) Scorpion MKIII 4035-530 Castle ICE2HV120 Futaba BLS255HV's on cyclic Futaba BLS256HV on rudder Futaba CGY-750 Futaba R6203SB receiver LiFe Source 2100mAh 6.6v battery FlightPower EONX 30C 6S 5000mAh batteries (2 for 12S) Radix 105 tail blades. Main blades - TBD (3 different sets sitting here, will try all 3, 1 normal, 2 sets FBL) Based on build information from Bobby and Brian at MA, build should be pretty quick. Hope to have in air on Sunday.
Team Futaba, Team Miniature Aircraft, Team Flightpower, Radix Blades, VelTye, YS Engines |
#3 |
kcordell,
What headspeed do you plan on flying and what gear ratio?
I like helicopters To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#4 |
Same as me. It will be here tomorrow. but the Helifreak funfly will prevent me from building this weekend.
My gear: Vbar full size Blue line JR 8917 HV for cyclic BLS251 for tail Castle 160HV Hercules Super BEC running 8.4 volts Thunderpower 5000 mah 65C packs Align 530KV 700MX motor Mavrikk 690 or 710 FBL blades Mavrikk 105 Tail blades Gryphon regulator for tail 6V 14 tooth pinion 2200 headspeed
Edsel Labao TEAM HORIZON HOBBY Blade Helicopters - Spektrum - Revolution |
#5 |
Stock gear ratio, 8.85:1 (124T main/ 14T pinion),
Headspeed, 2000-2200 (same as Bobby's setup depending on feel).
#6 |
Anyone got pictures of the box? Contents? Come on!
Team Miniature Aircraft USA Team HeliWholesaler, Team Byron Fuel's, Team Thunder Power, Team Scorpion -Darrick |
#7 |
I will post some tomorrow, currently in the HF funfly
#8 |
Posted my build pictures yesterday on Facebook.
Will test fly this morning.
#9 |
Here are some pics of the box and parts. I just got back from the helifreak funfly and only worked on it for about 2 hours. What I noticed is this will be a very quick build! I estimate less than 5 hours for the airframe. This is due to the low parts count and intuitive design.
The parts are so nicely made and the finish is the best I have ever seen. Take a look at the pics. It does not do it justice. I should complete the airframe in the next few days since I can only work on it a few hours a night due to family obligations ![]()
#10 |
MAN ! I'm excited ,hope mine ships soon
Nice pics |
#11 |
Xera 4035 2.5y 480kv motor
Castle Creations ICE 120HV Version 2 Thunder Power 12S 5000mah packs. Headspeed: 2100rpm Gear Ratio:8.857 VBAR mini BlueLine with Futaba 6203 3-channel SBus Receiver Straight 8 volts to VBAR( 5.2 Pro firmware) & SBus Receiver with Spekrum step-down to tail servo. Align 610 Servos on Cyclic Futaba BLS 251 on Tail Thunder Power 3800mah receiver Pack Mavrikk 690 mains, 105mm tail
Whiplash E, vbar Furion 6, vbar Fury 55, vbar Trex-700N, vbar |
#12 |
scorpion 4035-500
castle ice2 120hv spektrum ar 7100 beastx v3 jr ds 8917hv cyclic align ds 650 tail 2500 mah receiver pack and 5000mah flight packs 2@6s rotortech Scott Gray edition710mm mains and align 105 tail stock pinion until the 15T come in |
#13 |
final setup after 3 weeks of flying.
Xera 4530-500 motor Vbar full size Blue line JR 8917 HV for cyclic BLS251 for tail Castle 160HV Hercules Super BEC running 8.4 volts Thunderpower 5000 mah 65C packs Mavrikk 690 or 710 FBL blades Mavrikk 105 Tail blades Gryphon regulator for tail 6V 14 tooth pinion 2150 headspeed
