Go Back   HeliFreak > R/C Helicopter Support > 550 Class Electric Helicopters
550 Class Electric Helicopters 550 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Old 11-18-2011, 11:48 AM   #1
rogersrick123
Default Ordered 550mm blades by accident
I'm running a stock V1 setup 600MX motor and the helical gear 188/18t.
Will I have any problems with this? Is anyone running this configuration?
I don't mind trying it out I just don't want the heli to blowup lol
rogersrick123 is offline        Reply With Quote
Old 11-18-2011, 11:55 AM   #2
johnsandywhite
I have run both my FB and FBL with 600M motors and 170T MG and 16T Pinion with no problem. I just had to increase the head speed from 80% to 85%.
Been there and done that, but NEVER stop learning
johnsandywhite is offline        Reply With Quote
Old 11-18-2011, 12:23 PM   #3
Danny_Swe
Yo! Aha, that's 10,44 in ratio, a little lower than stock. Would be ok I think, have run my V1 completely stock (10,63) with MX-motor and 550-blades almost since maiden and it flies really well. At 1800-2300 rpm or something depending on flight style.
550E, X3 | BeastX, YGE, DX8
http://dannesholk.se/rc.shtml
Danny_Swe is offline        Reply With Quote
Old 11-19-2011, 10:08 AM   #4
Fredneck
Fly em.
I have the same gear setup but with the older 600M motor. 2150 RPM and the heli floats better now. Feels larger, I guess because it is sort of.
Logo 500
Logo 600
Fredneck is offline        Reply With Quote
Old 11-20-2011, 10:51 PM   #5
gadawg58
Do you not need a longer boom with the bigger blades?
George
XXtreme 800,XXtreme 700, Goblin 770,Goblin 700, Trex 450 Dominator, Blade 180
gadawg58 is offline        Reply With Quote
Old 11-20-2011, 10:58 PM   #6
koppterx
i forgot i had switched blades to 550 before i lifted off, so everything was set for the 520s. never changed anything, heli grooves very well, and still has plenty of pop. there is enough clearance for the tail blades. i think the trend will be towards larger blades as people start flying them. a
koppterx is offline        Reply With Quote
Old 11-20-2011, 11:12 PM   #7
Wolfpackin
No, not with the 550mm blades, but some would say to use the shorter 85mm tail blades to be safe.
Others fly with 550 mains and 90mm tail blades with no issues.
Jonathan Livingston Helicopter
Blade 400: E-flite 420H/35X ESC, AR6100e, HS65HB x 3, G401B/DS290G. (Ret.)
CopterX 450AE V2: 430XL/35X ESC, AR6100, HS65HB x 3, LTG2100T/HSG-5084MG.
T-Rex 550E V1 Classic Flybar: 600MX/BL70G, AR6200, DS610 x 3, Quark/DS650, 16t/520mm blades.
Wolfpackin is offline        Reply With Quote
Old 11-21-2011, 09:07 AM   #8
koppterx
the 90mm blades work fine. the downward arc of the main blades has plenty of clearance from the tail.
Old 11-22-2011, 03:04 AM   #9
v58fuy
Apart from autos, what is the difference in flight between the 520 and 550mm blades?
David
v58fuy is offline        Reply With Quote
Old 11-27-2011, 03:42 AM   #10
v58fuy
Can someone tell me how the heli reacts etc in flight with the 550mm blades compared to the 520mm blades.
David
Old 11-27-2011, 08:18 AM   #11
TeeRex001
David
With the 550mm blades, the heli feels larger and more stable compared to the 520mm, but in terms of agility and flight times, i think the 520 wins the 550.
Trex 550E V2, Trex 600E Pro with Scorpion HKIII 4035-560 ,
MicrobeastX Spektrum DX7
"Helicopters don't actually fly, they beat the air into submission."
TeeRex001 is offline        Reply With Quote
Old 11-27-2011, 12:03 PM   #12
Nko15
But it makes up for that in auto-performance.
Designing/Building the HEX Helicopters
Sponsored by Gens Ace Batteries, Gryphon Rotorblades, RCbearings.co.uk,
Nko15 is offline        Reply With Quote
