| Belt CP E-Sky Belt CP |
I just got this helicopter off ebay brand new for $179
Esky 3D Belt-CPX - 2.4GHz 6CH RTF - Orange After reading a few threads on this, I also got these items... EXI 450 Pro Head ![]() EFLH1451 Main Gear without One-Way Bearing: B400 and main and tail motor heat sinks. Anything else I should look into or know about this? |
I'm also quite new to helis, today being my first flight, infact. The Heli you got there looks nice, but I'm not sure it's easy to learn on. I was told to start with a coaxial heli then move to a fixed pitch. It appears that is a collective pitch chopper. Good luck, let us know how it goes.
#3 |
fly it as is.. until you have crashed it beyond repair then install metal head..
GOOD LUCK btw.. I have the orange CPX with an EXI HK TOROT ALIGN head get some training gear!!
Raptor 50 w/upgrades; HK500 w/Align parts; BeltCPv2 w/ trex style head; Belt CPX w/Trex style head. Still learning... To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#4 |
You can't use heat-sinks on this. The main motor is an out-runner, so you can't put a heat sink on it....and the tail is belt driven, so there is no motor to fit it to...
450 Bell 222, 450 Jet Ranger, HBFP Redbee Extreme, 500 size Blackhawk MH-60, 600 EP Spitfire, Sebart 342 30e, Davy Systems Flybaby, ST Models FW190, Micro SU26 & GWS P38. DX7s |
#5 |
Get training gear, and start by sliding around on the ground.
Also i strongly reccomend a simulator - nothing fancy - just to get your eye hand coordination going.
Roto-tilling, grass mowing, hedge cutting. Gardening when you least expect it... Franken MCPx, Franken 450 pro, RC Explorer tricopter v2.5, ST Blaze glider, Heli-x.net sim, Dx6i, JR 9303H 35mhz/2.4ghz, |
#6 |
and of course - there is rudds school of rotary flight ..
http://www.dream-models.com/eco/flying-index.html I crashed my BELT CP V2 within the first 30 seconds of switching it on.. and I thought I had read enough... so a word of warning.. DO NOT TOUCH the IDLE UP switch till you are acomplished at basic hovering !!
Chris, DX7 Electronics, Retired BELT CPV2 2 x HK600GT hybrids - + Blade Nano cpx ! DJI/FreeFlight Quadcopter several planks for relax time ! To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. I have not failed, I have just found 1000 ways that do not work. |
#7 |
I crashed in 30 sek. As well. I watched and read a lot of instructional vids, and they said slide arround on a hard surface, but I was eager and flew my first 30 sek. In high grass in the garden. http://www.rchelicopterfun.com/ has great tutorials.
#8 | |
#9 |
Not trying to burst your bubble, but xheli has the blue and green versions for about $10 cheaper. I really don't trust sellers on ebay, I've had some bad dealings with some of them.
Good luck, and get some training gear. |
#10 |
Hi tjb1, That helicopter is really a great one but it is difficult for you to learn how it works. You should try other heli that is easy to learn like coaxial heli's. And If you really want that heli you can learn from it. Just be careful. Enjoy flying!
#11 |
I agree with the training gear. Don't be too eager to get the heli in the air. Althought it's very tempting, don't try it in a small space. Big space are your friend. A basket ball court size space is good for sliding the heli around.
Don't even attempt to lift off the ground until you are very comfortable with the controls, and you can skid the heli any direction you want it to go, including when the heli's nose is pointed at you. Don't hesitate to post here for help!
- Jack Cranky old fart and charter member of ESO Lots of Helis To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#12 | |
#13 |
Ouch !!! Could we define "very comfortable" here ???
Jerry Trex 700N Pro fbl, 600N Pro x 2, 450SE v1, 250 v2 fbl, Compass 6HV fbl, Blade 450x, 400, 300x, 130x, mCPx, 120SR, mQx, mSR, Rotor Concepts HPQ1, Walkera CB180Q, CB100, Novus FP, CP, Esky Hunter, Big Lama. |
#14 |
You guys are already hopeless, this is a new fella we're trying to help out here.
#15 |
Nose in is devil's magic. I can do it in FF, but hovering.....nah, point it anywhere but at me!
#16 |
I started on the Belt cp v2 too! By comfortable I think it reacts slower than Mcpx and such smaller cp trainers. Also I feel it gives more pride of ownership. I later bought a Mcpx to train on. Because it can take a beating and survive, but I still feel 450 size and up is a real rc heli.
An important lesson is also that you have to enjy repair/tweaking as well as flying. You dont get much of that on the tiny cps
#17 |
I think CP helis are fine to start out on, as coax and FP don't behave like a CP heli. It does require more patience and restraint to start with though.
Sim time is important. Training gear as well. Make sure the center of gravity (CG) is good with training gear, battery and canopy mounted. Start on the ground and work your way up in height. Be patient and learn to hit throttle hold quickly if things start to feel outta control. Take a slow pace at first and get hovering in all orientations down first. I practiced changing orientation a few degrees at a time till I was confident working in around in a 360* orentation while holding it in a hover in one area.
R71d Futaba T8FGS - Gaui X2 and Heli-Max Axe 100CP. |
