Go Back   HeliFreak > R/C Electronics Support > DJI Heli Autopilot System(Naza-H/WooKong-H/Ace One)
DJI Heli Autopilot System(Naza-H/WooKong-H/Ace One) DJI Heli Autopilot System(Naza-H/WooKong-H/Ace One) Factory Support Forum
Old 01-23-2012, 10:08 PM   #1
spartan2381
Default WooKong- M Problem
I'm having a strange issue with my Quad and WooKong-M. After 60 seconds or so the quad will slowly turn left and I have to apply rudder or trim to correct than another 30 seconds later it will again start turning left, I apply more trim. Or sometimes after applying trim the quad will make a very quick turn to the left almost as if I slammed the rudder stick the the left. Any thoughts on what may be causing this?
spartan2381 is offline        Reply With Quote
Old 01-23-2012, 11:10 PM   #2
llbr22
compass calibration? probably need more info like setup, etc.
But you may also want to post this on multirotorforums or rcgroups (although abit of a mess on the later). Lot's more wkm users there.
Gaui X5, and lots and lots of multirotors
llbr22 is offline        Reply With Quote
Old 01-23-2012, 11:35 PM   #3
cbergen
In what mode? manual, atti, GPS?
Chris D. Bergen
Bergen R/C Helicopters
cbergen is offline        Reply With Quote
Old 01-23-2012, 11:53 PM   #4
spartan2381
This happens in atti mode.
Old 01-24-2012, 01:36 AM   #5
Tomstoy2
Have no idea, still trying to figure out programming issues with mine. Does sound like a compass issue though.
Have you tried re-calibrating?
Avant Aurora 90n,Trex 600E Pro, HC500, HDX450sev4, Trex 250se, mCP-X, Mosquito, X/A Hexa/WKM/UHF/FPV, F330 Flame Wheel,
PenguinV2/UHF/FPV, 757-3 ex Ranger/uhf/Ruby/fpv, QAV250 w/Vector , Ritewing Drak w/Vector Crossfire and fpv.
Tomstoy2 is offline        Reply With Quote
Old 01-24-2012, 01:37 AM   #6
gurudutt
Even I had the same problem, later I found my one motor was not align, I did that and problem was solve.
gurudutt is offline        Reply With Quote
Old 01-24-2012, 08:58 AM   #7
spartan2381
I did run through the compass calibration again. From what I can tell the motors are aligned.
Old 01-24-2012, 11:12 AM   #8
cbergen
One motor may not be responding as quickly or has a bearing going out causing more drag, or there is a bad electrical connection to a motor, as it heats up it creates more resistance, and again one motor is slower than the others.
Ensure that all props are balanced as well. A vibration may be affecting the gyros..
Chris D. Bergen
