| Flight Stabilization Flight Stabilization |
I was looking into and came close to buying a Profi. After listening to the Pros I hear many are ditching the high dollar stabilization for the HC3sx.
HC3a horizontal mode must be taught and saved with an assigned Tx switch. Then can be turned on and off with another assigned switch or slider. The degree of stabilization is only as good as you teach it. Does the HC3sx come out of the box ready to "see" horizontal mode by some electronic device? |
HC3-SX horizontal is pure gyro set level... same as HC3a, though with better gyros
MSR, MCPX, 450s, 600, 650, 700, 800, 900, 1000 Assorted Mix Fixed Wing. AMA # 972083 |
#3 |
I understand the rescue mode levels and climbs. Can you fly around in the horizontal mode without pitch being added by the sx?
#4 |
Acro/ Pitch (bail out) is a selectable option on the HC3-SX in the software, Horizontal is also selectable.
Can you fly in horizontal mode... absolutely
#5 |
As for the sx tail gyro, can I ditch my gy501?
#6 |
Mine holds well, but that will be your choice.
#7 |
Off to the store, thanks.
