| 600 PRO Class Electric Helicopters 600 PRO Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
hi dose anyone have the swashplate setting for the new DX8 or can upload full setup file for trex600 efl off there DX8 please.
swashplate set aileron = set elevator = set pitch = |
here are my setting's do they look right ? T-Rex 600 EFL PRO
swashplate set aileron = -43 set elevator = +37 set pitch = +41 Expo = off E-Ring = off |
#3 |
Are these with 3GX?
How much are ur pitch and cyclic curves? |
#4 |
the heli as 3GX on it i am using AR8000 with DX8
on swashplate i setup pitch 12+/12- and the aileron/elevator to 11+/11- then on my dx8 i set aileron/elevator switch 0 to 9+/9- and switch 1 to 10+/10- and switch 2 to 11+/11- i setup my pitch on F mode/idle switch 0 to -2 ,+5 ,+10 and F mode/idle switch 1 to -5 ,+5 ,+10 i did F mode/idle switch 2 the same as 1 for now ars thses ok swashplate set aileron = -43 set elevator = +37 set pitch = +41 Expo = off E-Ring = off or is there something not right in my build? |
#5 |
ok i just set it up again now i have
on swashplate i setup pitch 12+/12- and the aileron/elevator to 11+/11- then on my dx8 i set aileron/elevator switch 0 to 8+/8- and switch 1 to 9+/9- and switch 2 to 10+/10- i setup my pitch on F mode/idle switch 0 to -2 ,+5 ,+10 and F mode/idle switch 1 to -5 ,+5 ,+10 i did F mode/idle switch 2 the same as 1 for now ars thses ok swashplate set aileron = -50 set elevator = +44 set pitch = +43 Expo = Act E-Ring = Act |
#6 | |
I pretty much use the same settings on every heli I own in regards to pitch / throttle curves and it goes as follows: Pitch Normal: 30, 40, 50, 75, 100 or 0, 25, 50, 75, 100 Idle 1: 0, 25, 50, 75, 100 Idle 2: 0, 25, 50, 75, 100 Hold: 0, 25, 50, 75, 100 Throttle (w/o governor): Normal: 0, 45, 65, 85, 100 Idle 1: 100, 95, 90, 95, 100 Idle 2: 100, 100, 100, 100, 100 Hold: 0, 0, 0, 0, 0 Throttle (w/ governor) Normal: x1, x1, x1, x1, x1 (rpm #1) Idle 1: x2, x2, x2, x2, x2 (rpm #2) Idle 2: x3, x3, x3, x3, x3 (rpm #3) Hold: 0, 0, 0, 0, 0 NOTE: I use the Hold switch to turn the heli on and off when I use this function. |
#7 |
hi i think i've got it right now my 0 pitch was off i have redone the head and ball links now i have
set aileron = -42 set elevator = +42 set pitch = +42 Expo = off E-Ring = off on swashplate i setup pitch 12+/12- and the Cyclic pitch to 10+/10- then on my dx8 i set aileron/elevator switch 0 to 8+/8- and switch 1 to 9+/9- and switch 2 to 10+/10- DX8 as a switch F.Mode 0,1,2 it the same as Normal,Idle 1,Idle 2 F.Mode 0 to -2 ,+5 ,+10 F.Mode 1 to -5 ,+5 ,+10 F.Mode 2 to -5 ,+5 ,+10 Last edited by bedlam; 02-23-2012 at 04:38 PM.. |
#8 |
I think Align wants you to use as high of ail/ele swash mix % as you can. 42% seems too low. You should probably be around 80%. Try using the inner holes on the arms and make sure your endpoints are at 100.
#9 |
hi can anyone post there swashplate setting's on here please
