Go Back   HeliFreak > R/C Helicopter Support > Henseleit
Henseleit Henseleit Helicopters
Old 02-25-2012, 12:38 PM   #1
mkovalcson
Default You can never go over the top with a TDR :)
So far for this build, I've dyed gears, removed annotization from a heat sink and I just spent about 2 hours shaping my servo arms...
Henseleit TDR, Synergy E5, MSH PROTOS 500, 130X
Jeti DS-16, Skookum SK-GPS
mkovalcson is online now        Reply With Quote
Old 02-25-2012, 01:08 PM   #2
jhunter
Default That looks really nice
TDR, Srimok N x 2, Banshee 31, avant aurora, Dune!
jhunter is offline        Reply With Quote
Old 02-27-2012, 04:53 PM   #3
donskills
Will you dare fly the thing now?
Henseleit TDR 2011,GT-5. BLS451/251, Pyro 700-52, Jive80HV, Radix 710FBL, Radix 110 tails
Compass Warp 360, GT5, MKS 92/8910, Edge 60 tails.
Phoenix R/C, Futaba T14MZ
donskills is online now        Reply With Quote
Old 02-27-2012, 05:40 PM   #4
mkovalcson
I could have saved a lot of money in 65C TP batteries if I never intended to fly it!
Old 02-27-2012, 06:03 PM   #5
donskills
True!! you could have saved a ton of money on more than the TP's. The man hours put in not even counted. I waited 7 months only, during which I read the manual about 10-12 times, built it in 3 days, without the slightest hitch. The maiden raised my level of nerves to new heights and my thumbs can still wobble during first pack of the day and I haven't put down half the work on my build that you have!
Old 02-27-2012, 06:17 PM   #6
NevB
Glad I'm not the only one!
NevB is offline        Reply With Quote
Old 02-27-2012, 08:27 PM   #7
mkovalcson
I think I'm just about happy with the wiring.
Old 02-27-2012, 09:23 PM   #8
cbdane
Whew, one little mishap and that heatsink is going to tear the aluminum plate out of the ESC. It's just glued to the MOSFets.
Have laser, will travel.
cbdane is offline        Reply With Quote
Old 02-27-2012, 10:04 PM   #9
desertstalker
Easy fix for that, get some wire or similar and strap it down to the ESC mount. Heck string would probably do it.
-DX8
desertstalker is offline        Reply With Quote
Old 02-28-2012, 01:09 AM   #10
CyprusFlyer
Just ordered all the expensive stuff for mine, servos (Futaba), Pyro Motor, Jive 120HV ESC and the cooler:
http://www.fast-lad.co.uk/store/jcoo...0-p-17851.html
Hopeing it will provide protection for the ESC too (Must have a lot of gold in it lol)
Batteries from HK, going for 8 x 4500 6s for 4 flight packs 35-70C, adequate enough as the motor is 3kw/5kw peak, math say they are well in spec. Wont be doing crazy 3D stuff for a while yet.
Cost as much as the kit almost.
Anyone use the JLOG at all?
TREX 550E
LOGO 500SE & 600SE & 600SX
Synergy E7
zzzzzzzzzzzzzzTDR
CyprusFlyer is offline        Reply With Quote
Old 02-28-2012, 03:31 AM   #11
mkovalcson
I don't even have the ESC taped down yet. I still need to solder the EC5's.
Rest assured there will be some additional means of securing the heat sink before it takes flight.
Old 02-28-2012, 05:53 AM   #12
Tristin
Nice clean build, well done! Wow!
Tristin is offline        Reply With Quote
Old 02-28-2012, 06:23 AM   #13
mkovalcson
I think I have a much prettier solution.
There are two slots at the base of the heat sink on both sides. I believe I could fit a properly sized bolt through each side and I could secure that bolt without running something ugly across the top of the heat sink.
This would also double as a way to hold the heat sink down
Old 02-28-2012, 06:31 AM   #14
marcosp
And I thought "I" was neat... Great work!!!
Marcos
Marcos
Banshee #27, 2x TDR, Diabolo, JR Sylphide E12, Voodoo 600, Voodoo 400, Avant Aurora 90N, Rave 450, Gaui X2
marcosp is offline        Reply With Quote
Old 02-28-2012, 07:13 AM   #15
mkovalcson
Marcos
Thanks, I found a better way to mark my servo plugs too.
I used to use black stripes on the ribbon with 1,2,3 stripes. Now I'm using silver permenant marker on the Plug itself, so I have L, R, C, M for master on the BEC cables.
Off to the hardware store shortly to come up with a heat sink fastening system. I'll probably just use velcro tape to hold the ESC down.
I'm waiting until the batteries get here so I can figure out how far I should trim the ESC cables.
Old 02-28-2012, 07:43 AM   #16
pete914
beautiful man, nice attention to detail. If there were a concours show for heli's (maybe there should be?) you are well on your way to winning it. Post of up detailed pics when you are finished.
I take it you shortened wires?
Team Radix///
pete914 is offline        Reply With Quote
Old 02-28-2012, 10:00 AM   #17
mkovalcson
I have a proof of concept for securing the ESC without adhesive securely and allowing quick release.
What It found were that 6-32 x 2" bolts fit rather well. The threads actually catch in the aluminum heat sink so you have to screw it in, but they aren't so tight that they warp the threads. Put a lock nut on the end of it. Then grab a couple Protos 500 battery bands and you have a quick release system for your ESC
But... I think I need to find a better looking bolt maybe in black.
What do you think?
Old 02-28-2012, 12:28 PM   #18
AcidDrink
I really like how you mounted it. These protos o-rings are very strong, but still they would break in case of impact.
TDR/VBar
Logo 600SX 12s VBar
MSH MINI PROTOS/CGY750
AcidDrink is offline        Reply With Quote
Old 02-29-2012, 12:03 PM   #19
marcosp
Only con I see is the capacitors are over the edge of the tray. Not much you can do about it and on the TDR the whole front frame makes hitting the capacitors a lesser concern, unless the whole tray is reaped and it hit's something else.
Marcos
Marcos
Old 03-02-2012, 04:54 PM   #20
Danny_Swe
Lightbulb TDR - Polar Edition
...my sexy beast here. Have sanded the parts and spray-painted them white. I really dig white now.
ID:	295233   Click image for larger version
ID:	295234   Click image for larger version
ID:	295235   Click image for larger version
TDR, 550E, 450Q | VBar, YGE, DX8 | Olympus OM-D
http://dannesholk.se/rc.shtml
Danny_Swe is offline        Reply With Quote
