Old 02-28-2012, 01:36 PM   #1
tony_h81
Default Travel adjustment question?
Hi
i have build my first heli and now im setting upp my aileron and elevator pitch im using my dx8. Why does the servos move så slow when i using travel adjustment? right now travel is 100 and the servos moves fast but with about 20 degres pitch i want 10+- when my pitch is 10 degrees positiv and negativ my travel adjustment is about 30 travel and servos move very slow
What to do?
tony_h81 is offline        Reply With Quote
Old 02-28-2012, 03:51 PM   #2
newbheliusr
You don't use travel adjust to set your pitch. You use the swashplate menu. Change your pitch setting in there. Lower the number..........
newbheliusr is online now        Reply With Quote
Old 02-28-2012, 04:43 PM   #3
Wolfpackin
Travel Adjust is used to level the swashplate at high and low stick...and on Rudder to adjust piro rate.
Swash Mix is used to adjust the AIL, ELE and Collective pitch ranges once the heli is set up mechanically correct.
Zen and the Art of Helicopter Maintenance
Blade 400: E-flite 420H/35X ESC, AR6100e, HS65HB x 3, G401B/DS290G. (Ret.)
CopterX 450AE V2: 430XL/35X ESC, AR6100, HS65HB x 3, LTG2100T/HSG-5084MG.
T-Rex 550E V1 Classic Flybar: 600MX/BL70G, AR6200, DS610 x 3, Quark/DS650, 16t/520mm blades.
Wolfpackin is online now        Reply With Quote
Old 02-29-2012, 12:19 AM   #4
tony_h81
I forgott to mention i use beastx/Spektrum AR7200BX and i cant get acces to swasplate menu. Is there any other way to setting the cyclic pitch?
Old 02-29-2012, 08:30 AM   #5
newbheliusr
Step J
Heli's I've had:MCX2, MSR, HB FP V2, Blade SR, 120SR, Trex 250, Trex 450 sport, MCPX,
Heli's I have:
Trex 450 pro FBL BeastX (Clone Mostly Align), Gaui X5(SK540), X7(Vbar)
Old 02-29-2012, 10:04 AM   #6
newbheliusr
Honestly it sounds to me like you are confusing cyclic and collective pitch. You set your cyclic to 6 degrees of pitch on Step J. In step K you set the amount of collective pitch. You do this by moving the throttle stick all the way up and using the rudder stick to adjust how much pitch you get. You do the same with the low throttle.
If your mechanical setup is bad, or incorrect, or you have made mistakes on previous steps, you may find that is why you are getting such strange readings.
Old 02-29-2012, 02:01 PM   #7
tony_h81
ok thanks i did the setup from beginning and now everythings working as it should i notice the tail slider dont goes back to center after left or right rudder input, perhaps it does when the blades are spinning. thanks for helping!
Old 02-29-2012, 03:51 PM   #8
newbheliusr
The tail slider will never go back to center if you are in HH (heading hold) mode. Only in RATE will they go back to center.
Old 02-29-2012, 06:30 PM   #9
Wolfpackin
+1
