Go Back   HeliFreak > R/C Helicopter Support > Other Makes and Models Helicopters > AHF Aeolus
AHF Aeolus AHF Helicopter Support
Old 03-04-2012, 06:08 AM   #1
Rusty-
Default Fitting ASP 52 to Aeolus 50
I can't seem to fit my ASP 52 to my Aeolus 50. It came with the super combo kit form Hobby-Wing. It seems as though the clutch assembly is to long which makes the engine mount screw holes hang to low not lining up with the Aeolus' frame holes. has anyone had the same problem? What is the solution? Im frustrated
Rusty- is offline        Reply With Quote
Old 03-04-2012, 04:15 PM   #2
Grok
Not Familiar with the ASP 52, but it looks like the spacer (marked in yellow) is too long. Contact Hobby-wing to get the right part or have your local machinist shorten it the appropriate amount.
Grok is online now        Reply With Quote
Old 03-04-2012, 08:09 PM   #3
Rusty-
Yeah man, I sent ahf a message and they rekon the spacer for a prop needs to be removed( the one with a groove for belt start for a prop or something) is that the one you have pointed out or the first spacer? I'll try them both this Arve.
Old 03-04-2012, 09:13 PM   #4
Grok
Is that two parts? It looks like one part to me. Let us know how it turns out.
Old 03-05-2012, 12:40 AM   #5
Rusty-
Thanks Grok! Its all sorted. Had to move that grooved piece closest to the engine. Thanks man (The piece below the one your marked out) Thanks man Its fits all sweet now =)
Old 03-21-2012, 10:21 PM   #6
Hobby-Wing
On the engine, there are two spacers, one is iron spacer, the other is aluminium spacer. Take the aluminum spacer out of the engine, the problem will be solved.
Hobby-Wing is offline        Reply With Quote
Old 03-21-2012, 11:33 PM   #7
Grok
Rusty-, I missed your last post. Glad things worked out.
Old 03-22-2012, 01:12 AM   #8
Rusty-
Thanks Hobby-Wing and Grok. All is sorted. Went for mainden flight and doign my preflight checks I discovered my wasout arms bolt snapped in the base. Ordered an align. Hopefully stronger bolts. Also my Aeolus washouts bound up every so often.(Dont want that to happen in flight ahhh). I love the Aeolus build though, very nice machine.
Old 04-02-2012, 01:08 PM   #9
Heli-Chile
Hey, I am wondering if you could upload more pics after you have it done because I have the same problem!
Heli-Chile is offline        Reply With Quote
Old 04-11-2012, 09:28 AM   #10
Rusty-
Hey Heli-Chile, I hope ou have got it fitted by now and hadn't modified anything! I though I had set it up to send me emails if someone comments. Obviously not, sorry man. Okay just incase you haven't I prepared this picture for you.
Just remove that prop spacer that is outlined with the yellow box.
Please let me know how you have got on. Also if you have flow your bird. id love to know. Again, sorry about the slow reply!
Rusty-
Old 04-13-2012, 08:34 PM   #11
810darren
after i removed this i then ran out of thread and the bolt would then not tighten on the shaft i threaded it further and it tightened but now i will always be worried about it.
810darren is offline        Reply With Quote
Old 04-13-2012, 11:38 PM   #12
Rusty-
You ran out of thread, hmm. Im not sure how. Atleast its on thread now, chuck some loctight on it and it should be fine. Watchout for the nut though. It seems to be a very weak nut. My thread started to go after tightening it a few times. Keep an eye on it man.
