| Mikado V-BAR Mikado V-Stabi/V-BAR Flybarless System Software and Hardware Support |
#21 |
Just wondering, can the control panel tweak every parameter accessible on the pc software?
Or is it just for basic tweaking?
Shape 9.0, Goblin 700 (yellow & orange) , Outrage G5 all FBL** MKS Cyclics & Rudder Servos all round. Futaba SBus Rx, Futaba 8FG** transmission. |
#22 |
V-BAR Guru
Control panel can tweak all parameters, but not same logic functions as PC, i.e. you cannot install a new heli with it.
Android app on the other hand can do a new setup.
Gone fishing.. or hunting or something.. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#23 |
thanks Mel
#24 |
Just updated my MiniV to 5.2 Pro & i was looking for the Swash Ring feature but can't seem to see it, is it on the mini or is it only on the full size?
#25 | |
V-BAR Guru
It's there, Swash step in Setup, then the little doctors hat.
#26 |
Thanks Mr Mel
#27 |
Yet another one
, on the CGY750 you can mix out swash ball movements (interactions) by using Pit-Ail or Pit-Elev ect., can this be achieved in any way on the MiniV? My reason for asking this is because swash ball movement is quite evident on my Faifa with cyber head & MiniV though out most of the swash travel.
#28 | |
V-BAR Guru
If not, then its rather a geometry issue on the helicopter.
#29 |
Thanks for the uick response Mel
#30 |
V-BAR Guru
I flew my Faifa stock with some modifications to the head
Make sure the elevator lever does not hit the frame, if an older model it will, I had to dremel the frame where it hit. (fixed in later versions)
#31 |
I shall look into this, thanks.
#32 |
Ok, first flights were very impressive for how simple the setup is, GREAT!
The thing I have noticed is that in a bit of wind the Heli slightly dolphins when flying fast in a straight line, has anyone experienced this & if so how can I remedy this?
#33 |
My HF Map location Join Date: Jul 2007
Location: McKinney, TX, USA, North America, Earth, Solar System, Milky Way, Universe
Try lowering your cyclic gyro gain.
Alan (just call me "Bum"; no need to be so formal) HeliFreak Support Nankin Hobby Field Rep, Compass Support Team Helis: Compass Atom 500 (V-Bar), Compass Atom 6HV (V-Bar), Blade 130X, Blade mCPX Experience is something you obtain only after you need it. I wouldn't mind social media so much if it didn't involve people. |
#34 |
Hey everyone!
See this video after updated to version 5.2...incredible how great it was the flight!! : Bacon See ya! Joao Figueira Last edited by rockefile; 03-06-2012 at 03:23 AM.. Reason: Forgot the link |
#35 |
Where's the vid?
#36 |
Hi, here it is...
#37 |
Can anyone tell me if there is a cyclic ring (limiter) feature on the Vbar mini 5.0pro & if there is, where to find it?
#38 |
Yes: Swash setup tab, click on the blue doctor's hat.
#39 |
Can anyone tell me if the flagged up voltage drop warning in the log would explain my rudder failure today on my SHAPE 700 & if so what could be the cause of this? My setup is Helijive 120 running internal bec at 6V (with slave wires in), BLS251 tail servo with step down. Prior to this i did notice a few times before today my tail would make a slight kick in flight & this I noticed the very same day I enabled the autorotion bailout.
#40 |
V-BAR Guru
Please start an own thread next time.
- Are you using buffer pack? 6v on a Jive needs buffer pack. - I would rather guess static on that heli...
