Old 03-08-2012, 08:19 AM   #1
thehatguy
Default Reinstalling servo wheels
Got a good deal on a 700 minus electronics.
Starting to add equipment now.
Not having any experience with push/pull linkages, I am at a loss
as to how I should position the servo wheels.
Dont know what to use as a reference to get equal movement.
Looked through the manual, but didn't see anything that was helpful.
Any help is appreciated.
John
EX-HeliFreakSwag.com guy
(arthritis got the best of me)
thehatguy is offline        Reply With Quote
Old 03-08-2012, 10:52 AM   #2
Gene T
See those little triangular arms holding the ball link up to the swash? They are the thing that has to be at 90 degrees when your servo is at center. The way to establish 90 degrees is to draw a horizontal line from the hub that they rotate on, through the hole where the ball link is screwed into them. That line needs to be 90 degrees to your main shaft when at 50% pitch value (mid stick, zero degrees)
So power up and center the servos with the wheels off. Put your throttle to the 50% pitch point. Then line up the wheels to get the line as close to 90 as you can, then use subtrim to finish it off.
then do your swash leveling.
Blade mSR, Blade 400 in Airwolf Fuse, TREX 500, TREX 600, TREX 700 F3C V2, DX8, Phoenix, iCharger 208b.
Gene T is offline        Reply With Quote
Old 03-08-2012, 02:44 PM   #3
terrabit
Also, when your swash is level and centered, the bellcrank arm to swash link-balls should be centered to a reference slot cut into the cf frames. The same is true of the elevator link-balls. There's a hole that passes through both sides of the frame to use as a reference.
And, the servo horns should be 90° relative to the body of the servo. The push-pull linkrods should be of identicle length and should not bind when installed on to the output shaft of the servo.
vbar T700E v2 DFC head, Pyro 700-45L, Jive 120HV, BLS451/BLS251, Edge 693/115
vbar CF Protos Scorp 3026-880kv, Ice lite 75, 9650/BLS251, SAB 430/KBDD 82
terrabit is offline        Reply With Quote
