Old 03-08-2012, 09:07 PM   #1
2001rotax800
Default Help with Balance board/6s lead
I beleive I have been shipped the wrong parallel cable, I have an i1030b which can charge up to 10s, but it came with a 6s cable and a thunder power balance board. Can I make this cable work by moving the red positive wire to the far left? And if so how easy is it to move the wire in the connector? Thanks form a newbie....
2001rotax800 is offline        Reply With Quote
Old 03-08-2012, 11:49 PM   #2
Gregor99
Nope, that's correct. The 3010b uses a node wiring scheme that starts at ground and each cell adds another wire. The positive is just the next wire in the chain. This is commonly referred as the JST-XH wiring scheme. The FMA chargers use the scheme where the positive needs to be in the last spot. But even FMA has a mode that supports the JST-XH method. I know it looks funny, but its correct.
Greg
______________________________________________
Synergy E7 - Compass 600e - T500 - Trex Pro - mCPX
Gregor99 is online now        Reply With Quote
Old 03-09-2012, 07:22 AM   #3
2001rotax800
Well when I try to balance charge it gives me an error, balance board. Not sure why.
Old 03-09-2012, 09:57 AM   #4
2001rotax800
I am not able to balance charge, something is wrong. When I go to the monitor menu with 1 batt plugged in I can only see numbers on the 3rd cell, and even that is not right, wth?
Old 03-09-2012, 11:02 AM   #5
2001rotax800
After a phone call to David from progerssive RC the actual importer of the icharger into the united states, we determined that I did in fact have the wrong cable from the charger to the board. I was able to flip the wires mirror style going in to the charger, so I am up and running, thanks
Old 03-09-2012, 11:05 AM   #6
Gregor99
Thanks for the update. Glad you got it working.
Greg
Old 03-09-2012, 11:52 AM   #7
Gregor99
So I'm looking closely at your pictures and the wires does look correct on both ends. Compare them to the connector on your battery. With the ridges on the connector facing up, the postive (red) is on the left side. Its the same way for the adapter cable on both ends.
If reversing the wires corrected the issue, then it likely that all the JST-XH connectors on the balance board were installed backwards. While reversing the wires in the connector at the either end corrects this, it might not have corrected for the TP connectors. Also you would not want to use that adapter cable for any other board.
Greg
Old 03-09-2012, 01:14 PM   #8
2001rotax800
It was explained to me that they sent me the wrong parallel cable, I could have either had them send me a new one, or flip the wires, I chose the second. I am running my first cycle charge discharge now, on one of my new batteries. I will post and updated pic of the new wire config.
Old 03-10-2012, 09:56 AM   #9
xpftp
if red has to be 1st on the charger... why not just knife the lil edges off .. 2 secs and bang done ??
or on the board side of the plug .. not sure what side is backwards..
and then flip the cont itself over ..
B400 gotta love the old girl / 250 / 500 ..
Turn Up The Juice. See What Shakes Lose
xpftp is offline        Reply With Quote
Old 03-10-2012, 10:29 AM   #10
2001rotax800
I beleive its because the cells go from right to left, and the red needs to be the first. The center wire stayed the same, 1 went to 7, 2 went to 6, 3 went to 5 and 4 stayed put.
