Go Back   HeliFreak > R/C Helicopter Support > NextD - Rave 450 and 90
NextD - Rave 450 and 90 CJY Rave 450 and 90 Helicopter Kit - ND-YR-K001
Old 03-15-2012, 10:01 AM   #1
trapid1
Default Helical gear for rave
Can anyone tell me where to get helical gear for rave env, not good that you can't get main gear of all things, I pre orderd now 2 months. Not right!!!
Sent from my SPH-D700 using Tapatalk
Tino-SRW
trapid1 is offline        Reply With Quote
Old 03-15-2012, 11:28 AM   #2
mystar60
http://curtisyoungbloodhobbies.curti...categoryId=167
CYE Field rep
http://curtisyoungblood.com/
Ballistic 700,Ballistic 635, Rave ENV Nitro, Rave 450, TotalG, MP7, Radix Blades
mystar60 is offline        Reply With Quote
Old 03-15-2012, 11:52 AM   #3
Sky Dancer
You can get the molded Ballistic helical Gear, it works just fine.... CY has them in stock!
http://curtisyoungbloodhobbies.curti...categoryId=148
Don C
Sky Dancer is offline        Reply With Quote
Old 03-15-2012, 04:16 PM   #4
trapid1
thanks for quick reply guys, i seen on amain hobby site the gear has to be pre order and its $70.
Old 03-15-2012, 05:12 PM   #5
MarshallB
Don't believe that's right. It says 69 but it's 49.99 on the CY site. That's also the cnc machined gear. The molded version is 24.99 like Don says and is in stock.
CurtisYoungblood.com, Next-D, Spyder Batteries
MarshallB is offline        Reply With Quote
