Old 03-17-2012, 08:02 AM   #1
chucky21022002
Default Bank switching on 8fg help..
I watched Mr Mels video on bank switching over and over again but I could only get 2 banks in three positional toggle switch while one the video, Mr Mel has three. Any tips on how to achieve this? Any input is greatly appreciated.
Sent from my GT-I9100 using Tapatalk
Copter X Hybrid Beast X Castle Gov
Trex 500 Vbar Castle Gov ,Trex 600 ESP 12S Vbar Gov
Compass 7HV Mini V Gov
Compass 6HV Vbar Castle Gov
chucky21022002 is online now        Reply With Quote
Old 03-17-2012, 04:58 PM   #2
Deet
on the 8FG its easy, just select the gyro menu to switch by condition (flight modes)
then you can set the banks based on the number of flight modes you have enabled (you need to enable each flight mode and assign its switch)
the max on futaba is 4 flight modes
typically the three osition switch on the left top of the radio is normal, idle 1, and idle 2, then the long switch at the back is idle 3. idle 3 overrides the other flight modes.
then you set the gyro gains to give you the various banks as required
Dave
Goblin 500, Vbar, BLS153, BLS251, Kontronic Jive & Piro
MutliWiiCopter Scarab Stealth Armour, Scarab TriiKopta, Scarab Octa, Scarab Vampire
Deet is offline        Reply With Quote
Old 03-17-2012, 07:49 PM   #3
chucky21022002
Thanks Dave, appreciated.
Old 03-18-2012, 04:56 PM   #4
chucky21022002
Just an update, I managed to sort out three banks on my three postion toggle switch.. Thanks a lot Dave.
