Old 03-24-2012, 01:32 PM   #21
NRPY
Originally Posted by terrabit View Post
I walk this June but, I'm 46.
Congrats, man! It's never too late. It takes so much more effort and concentration to finish a degree when you're older. Buy yourself a nice graduation present to celebrate your accomplishment.
NRPY is offline        Reply With Quote
Old 03-24-2012, 06:02 PM   #22
nightflyr
Lightbulb 700E Kframe in the works
It's a new design ...but it ain't from any of the big companies..
DTS, top adjustable mounted motor using stock mount, 3rd bearing block, adjustable pinion support using stock support
MSR, MCPX, 450s, 600, 650, 700, 800, 900, 1000
Assorted
Mix Fixed Wing.
AMA # 972083
nightflyr is online now        Reply With Quote
Old 03-24-2012, 06:09 PM   #23
K2Freak
oooooh! aaaaaaaaaah!
That looks amazing!
T-Rex 800E CHP DL / VBar / YGE 160HV / X-era 4030 470kv / MKS DS660A+ & DS760 / Align 780mm / Gryphon Quasar / KDE performance tail
K2Freak is offline        Reply With Quote
Old 03-24-2012, 06:36 PM   #24
nightflyr
It's getting there....
for Kelly!!!
Assorted
Mix Fixed Wing.
AMA # 972083
Old 03-24-2012, 10:36 PM   #25
terrabit
Thanks! Did I actually say I'm 46? Doh! I'm 44. Anyway yes, it's been a long haul. I started college as a highschool dropout. BS in June, CPA exam roughly a year later and MBA some time after. The hardest part has been adjusting my standard of living. I got into this hobby with a $60 income. I'm at less than half that now. That in itself is hard to do at 44.
vbar T700E v2 DFC head, Pyro 700-45L, Jive 120HV, BLS451/BLS251, Edge 693/115
vbar CF Protos Scorp 3026-880kv, Ice lite 75, 9650/BLS251, SAB 430/KBDD 82
terrabit is offline        Reply With Quote
Old 03-26-2012, 12:57 PM   #26
suomynon
Yes.
I just heard there is a new design coming end of May.
Compass Atom 7HV. Align T-Rex 550.
suomynon is offline        Reply With Quote
Old 03-26-2012, 01:23 PM   #27
akamullen
Originally Posted by suomynon View Post
Yes.
Heard from who/where?, just curious. I know Zsabo was over there testing the 450 DFC head. did not hear of a 700E revision, but you never know, ALIGN seems to update/revise parts and kits very often.
AnythingHeli.com OWNER/ TEAM PILOT
GAUI X5 / X7 *
GOBLIN 500/630/770 * TREX 500DFC / 450DFC@6S * Swinging EDGE & SAB Blades * Microbeast/IKON * Castle ESC's on all * Beating on all
akamullen is offline        Reply With Quote
Old 03-26-2012, 06:03 PM   #28
trexpaul
Align is working on new 700 with direct drive for the servos no more bell cranks servos will be direct to the swash plate they are testing servos now to see which gears last the longest
The nitro version will be out first and about 2 to 3 months after the electric will be out
trexpaul is offline        Reply With Quote
Old 03-26-2012, 07:54 PM   #29
so-fly
I hope it's just the frames lol that way I can just do a conversion over to direct drive. And a few links/horns
ALIGN TREX 250SE 450SE V2 500ESP 550E 600ESP 700E
NOVUS CP
BLADE MSR BLADE SR 120 BLADE SR
so-fly is offline        Reply With Quote
Old 03-26-2012, 10:14 PM   #30
NRPY
LOL! Sounds like a lot of wishful thinking in this thread.
Old 03-26-2012, 11:30 PM   #31
terrabit
Very happy to hear this. I'm surprised that Align stuck with the bellcrank config for so long. Especially given that the push for reduced parts count and lighter weight has been so intense.
Old 03-27-2012, 07:01 AM   #32
QYT001
I like bellcranks - saved so much servos for me )))
T-Rex 700N: JR DS8717HV; Vbar 5.3+Outrage BL9188HV; Outrage BL9080HV/Throttle; Gryphon regulator; SG; OS MAX 91HZ-R
T-Rex 700E: JR DS8717HV; Spartan Quark + Outrage BL9188HV; CC ICE HV 160A; RCM-BL700MX (470KV); WR Super BEC
T-Rex 250SE 350Watts
QYT001 is offline        Reply With Quote
Old 03-27-2012, 07:26 AM   #33
terrabit
I'll sell you mine very cheaply once I convert.
