Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > SR
SR Blade Helicopters (eFlite) SR
Old 04-16-2012, 01:19 AM   #1
BigRHS
Default Bearings for blade grips ?
Hi guys,
I had a vibration when I would spin up and found that i had a bent feathering shaft. So while i was into it, i decided to replace the main shaft, and the flybar. While I was replacing the feathering shaft I accidentally pushed out one of the bearings in the grip. it was the one that is closest to the dampening ring, anyway, it went flying across the floor and down a drain that is in my basement, no getting it back now.
I have done a little search on google but i can't seem to figure out which bearings I need. Does anybody know where i can get a set of these.
I called my LHS and they don't have any.
I am grounded until i can one or a set so any help would be really appreciated !
Thanks.
DX8, MCX, 2 MSRX's 1brushless, 4 MCPX's 2-V1's 1 brushless & 2- V2's, 1-130X, and 1-300X and a Harbor Freight carry case, & Venom TX case.
BigRHS is offline        Reply With Quote
Old 04-16-2012, 02:00 AM   #2
BigRHS
Update,
I think i finally found a set of bearings to replace the lost one in my blade grip.
If someone wouldn't mine to take a look at my link here and tell me if these are the bearings i need.
http://www.ebay.com/itm/280689918262...84.m1497.l2649
Thanks for your help
Old 04-16-2012, 06:40 AM   #3
ryanjameshay
The bearing you need is number 23 on the exploded view parts list. Its bearing 3 x 6 x 2.5, EFLH1115. That ebay page is exactly what you need. Check this out too:
http://www.horizonhobby.com/products...ing-2--BLH1115
ryanjameshay is offline        Reply With Quote
Old 04-16-2012, 10:39 AM   #4
BigRHS
Thanks so much for confirming that for me. I look on HH site but for some reason I must have over looked it.
But i did order the ones on that ebay page so I should get them in a couple of days.
Again thanks !
