Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > mSR X
mSR X Blade Micro SRX Helicopters Information and Help
Old 04-21-2012, 06:46 PM   #21
tbullard
Originally Posted by msrxnewb View Post
i finally did it, two days ago. it was pretty nerve racking. my RHK blade grips took some damage after a few attempts, had to bent it back with pliers and then it was perfect again!
Make sure you have your D/R set to 100% on Aile and Elev and also it helps to have your travel adj set to 125% on Aile and Elev. Should be no problem to make the flip with those settings.
tbullard is offline        Reply With Quote
Old 04-23-2012, 11:01 AM   #22
burnoutboy
Or you could just nut up and do it with the stock TX like me LOL.
Can't wait to save enough cash for a DX6i. It should make all the dumb stuff I do so much easier. I'll be able to do even dumber stuff that this heli "can't" do.
DSMX DX6i, MH mCX2, mSR, BL RKH mSR X, 3 X mCP X v.1 (one stocker, one destined for DBL, one destined for DBL mini130X), Lachmund mQX
PM me for your soldering and mSR X BL build needs.
burnoutboy is offline        Reply With Quote
Old 04-28-2012, 12:38 AM   #23
greyhoundfan
Well, I almost did.. but I chickened out.. I got the heli as high as I could and than gave fwd command, just at the tail end of the descent it started to front end flip, I let this go for a just a second and a half and pulled out of it. I did this 3 or 4 times but didn't have the 'stuff' to fully commit..
greyhoundfan is offline        Reply With Quote
Old 04-28-2012, 08:33 AM   #24
burnoutboy
Get it higher or try a backflip. You don't need as much altitude to backflip as you do to front flip in my experience.
