Old 04-16-2012, 03:34 AM   #1
babajaga
Default TT pro 70H
HI everybody, my english its no so good, I hope that we will understand me. I have problem with this engine, doest not run. I think the carburator its out of tune. How many turns do I have on the mixture methering screw? I think that here is problem. The needle valve I have on 2,5 turn open. What need I set up as first? Glow its ok ( os max no.8 ). Thanks for all advices.
babajaga is offline        Reply With Quote
Old 04-17-2012, 01:33 AM   #2
babajaga
Nobody can help?
Old 04-17-2012, 08:02 PM   #3
crflyer
The manual doesn’t give the factory settings for the idle mixture . I had a similar problem.
Close the carburetor completely, close the idle mixture screw (turn clockwise) completely.
Open the mixture screw 2 turns, this will get the engine started and you can tune from there.
2.5 turns on the high speed valve should be ok, this engine like to run a little rich .
crflyer is offline        Reply With Quote
Old 04-18-2012, 12:07 AM   #4
babajaga
You have right, in manual is nothing about the mixture screw. I will try it. I was trying start it yesterday and the motor doesnt start...I dont know where can be the problem. What glow plug do you have? My motor runs good and one dat I tune it a little bit and then I cant start it.
Old 04-18-2012, 09:52 PM   #5
crflyer
I use an OS 8 glow plug,if it still will not start make sure the carb is clean.
Good Luck
Old 04-19-2012, 12:41 AM   #6
babajaga
OK, thanks, i will try it this weekend.
Old 04-19-2012, 03:44 PM   #7
babajaga
and how much % of nitro do you use? I have 20%
Old 04-19-2012, 08:48 PM   #8
crflyer
I use Cool Power 30%
Old 04-20-2012, 02:32 PM   #9
babajaga
I was trying today...the engine doesnt make any bafff...nothing. I install new gasket under the head, new plug os no 8, clean the carb, fuel filter...I am insane about it...the plug was dry, there was no fuel I think. When I bung the muffler, the air pressure to the tank was so weak and the fuel doesnt make any, or minimal move in the tubes...I had everything checked and the tubes are floating...It seems like small compresion or what...? Its something that I can checked when I demount the motor...? I dont know what can I do...
Old 04-22-2012, 06:36 AM   #10
babajaga
I had to order a new piston ring, new piston and new cylinder liner...I hope this helps...
