Old 04-25-2012, 12:57 AM   #1
breathe rc
Default AR7200BX and USB PC programming?
Ok, I have 2 AR7200BX. One on my Protos, and one on my Srimok 90N. The Protos didnt take much to get flying very nice. The Srimok on the other hand wasnt so pleasant. Had vibe issues on first few flight attempts, and heli kept pulling to the left. Finally added some zeal tape, and that did the trick. With the Protos, there wasnt a need to adjust the gains, much, if any. The Srimok is taking more adjustments to get it right. All this being said, basically to ask, how do you program the AR7200BX via PC? I downloaded the BeastX software, but its telling me they aren't compatible. So is programming via PC not an option at this time? Or am I just doing something wrong?
If there's better, I want it.
Kasama Dune 600: Pyro 700-52, Jive 80HV, V-Bar, BLS451's, BLS251
breathe rc is offline        Reply With Quote
Old 04-25-2012, 03:54 AM   #2
Down Low
No, pc programming is not an option at this time for the 7200bx.
Airtronics SD10G, SK540, OS.50 Hyper (possibly tweaked a little)
Synergy N5c
MAAC #85462
Down Low is offline        Reply With Quote
Old 04-25-2012, 08:34 AM   #3
scott s
A couple of weeks supposedly microsettings for ar7200bx should be available. Yes using beastx usb. Keep an eye on horizon site but I sure it will be posted here as soon as available.
scott s is offline        Reply With Quote
Old 04-25-2012, 09:29 AM   #4
breathe rc
Ok great. Thanks for the info. I will be keeping an eye out for it then.
Thanks again
Sent from my iPhone 4S
using Tapatalk
Old 04-25-2012, 12:51 PM   #5
dunkonu23
Where did you hear that?
Scott
Spartan Vortex VX1 Inside
Team A Main Hobbies/ProTek Field Rep
dunkonu23 is offline        Reply With Quote
Old 04-25-2012, 01:04 PM   #6
scott s
Scott
#12 dribbe
Originally Posted by sutty
I would say that the performance is almost identical, at the moment.
1) There is no microsettings software to allow you to fine tune some of the flight parameter features. These can be button and stick programmed, but with the microsettings software you have much finer control resolution, and not just three of four preprogrammed values.
Working on catching this up... Not a permanent situation.
2) At the moment the firmware releases are effectively the same, but if MB release V4, or more, then as it stands the AR7200BX will be left behind, and the performance will differ more and more.
Assuming V4 may be coming at some point.... the AR7200BX will be kept up to date (not left behind!). It is possible that there maybe be up to a few weeks of delay, but maybe not.... It is presently up to date.
So far no one can extract any information out of HH as to if and when the microsettings and update software will become available.
Working on it.... Hope with-in a couple of weeks... Understand you can wait and see!
Personally until this is resolved I would not buy one, as who knows what wonderful features might be available in V4, V17, etc, lol.
Cheers
Sutty
above (and reflects the agreement of support we have with FW).
Regards,
David
Horizon Hobby Product Development
Old 04-25-2012, 01:30 PM   #7
dunkonu23
Then that's great. Thanks.
Scott
Old 04-25-2012, 04:11 PM   #8
breathe rc
Yeah, I chose the AR7200BX because I didn't want to have to buy a RX too. The AR7200BX is my first experience with BeastX, and u love it, even without the PC option. I've tried 3G, 3GX, SK720, and Vbar, and the AR7200BX is the one I like most. I always had my PC in the field to adjust my Vbars, and I never got it to where I loved it. Actually crashed my Heli twice from vibe issues with the Vbar. I had vibe issues with the AR7200BX, and it was still controllable, and I was able to land and fix the problem.
Anyway, hope the PC option becomes available soon. I would like to see how much better I can get it to fly.
using Tapatalk
Old 07-27-2012, 10:18 AM   #9
kvandenbroucke
Hi,
i just started with a 300X and the ar7200bx receiver on it
I'm a newbie to this but i like pc interfaces so i found this:
http://www.horizonhobby.co.uk/aeroon...face_sheet.pdf
Actually i was looking on the spectrum website.
I don't know if it is only for firmware upgrade or also usable for changing the settings
DX6i, blade 450 3D, mcpx c05m, mcpx v2 stock. 2 x blade 300X. Started with a solo pro 2 years ago.
kvandenbroucke is offline        Reply With Quote
Old 07-27-2012, 10:11 PM   #10
breathe rc
No that is just for software updates. Haven't checked lately, but last I checked the AR7200BX wasn't capable of being setup thru PC. If someone knows if that has changed, please let us know.
using Tapatalk
Old 02-11-2013, 12:03 AM   #11
Skibum44
Any chance that you could adjust it with the computer yet?
Skibum44 is offline        Reply With Quote
Old 02-13-2013, 07:58 AM   #12
lotus7
Some Setups and all Parameters can be set up with the link and a PC
Lotus7
Compass 6HV
Compass 600E
lotus7 is offline        Reply With Quote
