Old 04-25-2012, 12:58 PM   #1
Rajii
Default More Loc-Tite!
While flying the 500esp this weekend I noticed that it was very difficult to maintain any control and things just seemed out of whack. Back at home I found the issue. I use the standard blue loc-tite on everything, but for some reason these screws backed out. Only 35 flights since last repair/rebuild too. Anything I could do different?
Name:	500esp Head Problems 0.jpg
ID:	311082   Click image for larger version
Name:	500esp Head Problems 1.jpg
ID:	311083   Click image for larger version
Name:	500esp Head Problems 2.jpg
Rajii is online now        Reply With Quote
Old 04-25-2012, 02:10 PM   #2
ChopperNoob
Loctited screws shouldn't really come loose like that. My guess is that maybe your screw threads were contaminated with oils or grease before you assembled them. I use loctite in this hobby and in my job and ive never seen screws come loose like that before. Even in worn threads. Maybe try cleaning your threads with acetone or brake/clutch cleaner before assembly see if that helps.
Trex 500 FB - Trex 450 Pro V2 3GX - Mcpx
ChopperNoob is offline        Reply With Quote
Old 04-25-2012, 03:19 PM   #3
torpedoarmed
Close call. I have had allot of teardowns and rebuilds because of a single crash that gave me the vibes on a FBL 500. Because of that allot fo thread lock was used and built up in the threads on the screws and holes.
I bought a set of tap/dies 2.00/2.5m/3.00 mm and the first clean out of these threads was shocking. I specifically remember the tailcase threads where the fine attaches is was so gunked up.
I would suggest the 50.00 USD investment, you have already seen an instance where this would be minor compared to the possible crash costs.
When using them, I coated the tap or die with mavel oil to avoid messing the threads up. Once cleared of the gunk I used a can of carb/choke cleaner to blast the oil residue out and make for a prepared surface perfect for new loctite.
Chris
torpedoarmed is offline        Reply With Quote
Old 04-25-2012, 03:54 PM   #4
ddj74
Never had an issue with the blue locktite. Matter of fact when i go to take something off i almost have a hard time getting the part undone. As said before possibly oils or maybe not enough locktite applied. I usually use a toothpick and apply the locktite into the threads to make sure its coated decently but make sure not too much.
T-REX 700 DFC v3, AR7200BX, ICE2 160HV,DC-UP MARK II
MKS HBL950 & MKS HBL980, GRYPHON EXTREME REGULATOR
POWERED BY THUNDER POWER LIPO'S
ddj74 is offline        Reply With Quote
Old 04-25-2012, 04:28 PM   #5
Blayd
As stated.. it was probably oil contamination.. loctite WONT set up if there's oil in the mix.. it stays a liquid. And it doesn't take much. I always use acetone over alcohol.. both work to clean, but Acetone evaporates very quickly.. alcohol can take some time depending on how much you use...and it , too can cause breakdown of the Loctite if its not totally dry before you use the Loctite. You just have to be careful with Acetone.. it can ruin some plastics... but so can Loctite.. Acetone just does it faster.
Another thing.. I'm glad you got lucky and got it down in one piece.. BUT.. ( yes.. here's the old mans lecture...) I do a FULL preflight and Post flight inspection. I know, I know.. over kill.....I treat these things like I did when I flew small planes...Every thing I can get a driver on, gets checked before flight day, and when I have time after flight day. I mean EVERYTHING. It sounds anal, I know... but it increases your chances of finding a problem BEFORE its a disaster.
Good on you for realizing there was an issue and bringing it in before something really bad happened....
OH.. and a note... the cap screws that hold the seesaw... not the ones that hold the arms....I just recent had a set strip out the block they screw into...I had to replace it...once I saw how short the threads are in those.. I' am surprised there arent more issues with them.....be sure to check the block really well...
Trex700N2E
Trex500ESPTT(PRO head and Tail )
Trex500ESP (Belted)
HC500SE All flying Spartan, CC100A, CC20APro, Hitec 5245MG, Futaba 9257, Walkera Devo 8S, KBDD, i2!
Blayd is offline        Reply With Quote
Old 04-25-2012, 05:02 PM   #6
Rajii
Thanks for the suggestions. I'll definitely be taking a little more time to make sure everything is clean and loctite is applied.
On he bright side, I was able to fly enough to put a pretty decent groove in the arms and not crash! Must be getting a little better!
Old 04-25-2012, 06:43 PM   #7
Blayd
Trex700N2E
Trex500ESP (Belted)
Old 04-25-2012, 07:06 PM   #8
Mateyhv
Never had problems with the blue loctite. I always apply small quantities, only two or three thread covered and it holds great.
Mateyhv is offline        Reply With Quote
