| Kasama Helicopters and Upgrades Kasama Srimok 90 Helicopters and Upgrades Discussion |
How many people have kasama srimoks and what is there setup.
I do have one Nitro and here is my setup :
OS 91 HZ + Hatori SB19 + Kasama Header Futaba CGY-750 with LRH / comp grip arm upgrades 3 * BLS-253 + BLS-251 Scott Gray Reactor X2 Blades SAB or CY Radix 690 / 105 You should also check-out the Kasama forum !! http://helifreak.com/forumdisplay.php?f=208 |
#3 |
1: os91hzr hatori bls 451/251 vbar reactor x push glo radix
2: os91hzr speed hatori bls 351/251 vbar reactor x push rail blades
TDR, Srimok N x 2, Banshee 31, Dune! |
#4 |
Srimok 90N with Cyber LRH
OS 91HZ-R 3D Speed, Hatori SB20 JR 8915, MP80G Skookum SK720 Gryphon GVR 7020, Auto Boost Edge 693SE, Edge 105 or Radix 710 v2, Radix 105 And ask in the Kasama forum. |
#5 |
Probably better to ask in the Kasama forum !
Srimok ECO OS 91 HZ + GP Exhaust Nitropower 91 CGY 750 Radix 710 FBL & 95 Srimok 90N OS 91 SZ Flybarred Radix 710 Srimok Faifa Pyro 700-52 & Jive 120 HV VBAR. 5.1 Radix 710 FBL
John |
#6 |
srimok faifa
kontronik jive 80HV kontronik pyro 700-52 futaba bls 451 swash futaba bls 256Hv tail v-bar blueline fullsize 5.2 radix 713mm fbl blade radix 105 tail blade turnigy 4000mah*2 hyperion li-fe 3200 reciever pack best flying helicopter in my hangar ![]() Last edited by casper hansen; 04-20-2012 at 05:42 AM.. |
#7 |
Srimok 90E FAIFA with competition arm grips and lowrider head
Motor: Pyro 700-52L ESC: HeliJive 120 cyclic: Savox 1258TG tail: Savox 1290MG V-Bar 5.2 BlueLine Rail 696 + Rail 106 12s4300 50C battery Srimok 90N ECO with competition arm grips and lowrider head Motor: OS105HZ-R + Hatori 2105 Gov: ATGv3 cyclic: Savox 1258TG tail: Savox 1290MG V-Bar 5.2 BlueLine Rail 696 + Rail 106 Srimok 90N with competition arm grips and lowrider head Motor: OS105HZ-R + Hatori 2105 Gov: ATGv3 cyclic: Savox 1258TG tail: Savox 1290MG V-Bar 5.2 BlueLine Rail 696 + Rail 106
helistore.at - Your RC Helicopter specialist in Europe! HeliStore on Facebook: facebook.com/helistore |
#8 |
Srimok 90E Faifa
KASAMA SRIMOK 90E Faifa FBL VBAR HK-4525-UE PRÔTOS 500 FBL AR7200BX CF HK-3026 PRÔTOS 500 Stretch FBL Brain CF HK-3026 Blade 400 M.I.A, mCP-X BL, MSR, Syma S006-clone |
#9 |
Faifa,
low rider head conv. 4525le powerjive 120 outrage torq 9188 tail ds610 cyclic vbar pro gryphon quasar bec radix 710 fbl/edge 105 tp 5000/4400
Kasama Faifa 4525le Vbar LRH Stretch 12s 550e Rexy Vbar DFC Compass 7HV Vbar Trex 450pro sk540 |
#10 |
Srimok 90N
Flybared with Align OS91HZ converted to HZ-R SB19 Exhaust 3 x BLS252 + BLS251 S9254 on the engine Gryphon Extreme Spartan Quark Srimok Faifa Flybarless- GT5 Ace RC Scorpion 4525LE Kontronik Jive 120 3 x BLS451 + BLS251 Gryphon Extreme Powered by Gens Ace 5300mah |
#11 |
1 Faifa
SPEC : BLA 157HV, BLS256HV Scorpion 4035 Phonix 120A
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. KASAMA Part from Thailand as Fast as Possible |
#12 |
Srimok 90N,comp arm grips,lowrider head, 2xcarbon landing gear
Motor: OS91HZ-R 3d speed + Hatori #968 Gov: Multigov pro cyclic: JR8917hv tail: 9188 throttle: 9180 Gryphon GVR 7020, Auto Boost SK720, powerbus Rail 696 + Rail 106
250| 450 Sport| 450 PRO| KSM Srimok 90n| KSM Dune| Compass Warp360 |
