| mCP X Brushless Mods Blade Micro CPx Brushless Mods and Conversions |
So I wear out the dampners really fast.... About 100 flights or less and they get very soft. They're pretty darn soft to begin with, with the all metal head and the increased mass it doesn't help. (don't talk to me about excessive bling, I haven't broken a single head component in 400+ flights. Even my MH swash is still PERFECT with no slop. Can't say that about the plastic).
I think the dampners work great stock, but with brushless it's not enough for me. I'm hard on the cyclic. Does KBDD plan to make any? Is there a substitute? I've tried the thicker brass washers that came with the MH head, and ended up going back to two stock washers on each side. Helps alot to stiffen up the head, but it just needs more.
Blade 130X - Stock mCPx Brushless Stretch (125mm) - WK10A - 11000kv Inrunner - 550 mah - Full CNC Upgrades Logo 400 - Parting Out - Need parts PM me. Retired Helis - Outrage 550, Trex 500, Others |
Use these instead of the stcok dampners. They are much harder and I use them on all my conversions.
http://www.oringsandmore.com/servlet...h-rings/Detail
Team Newb pilot BL mCPx (HP06V2 motor/HP03 tail),130X with HP08 motor,Trex 450 Pro V2 (KDE450XF motor,iKON),Trex 500 ESP (KDE500XF motor, iKON),DX7, AMA# 966513. PM me about mCPX & NanoCPX BL conversions. |
#3 |
I use the stock dampners but with extra washers, I took off the step of the stock brass washers and added 1 per side.
So its 2 washers per side instead of the one.
Dx8 mCPX bl v1 hp05s130X GauiX2FESds11,ds95i beastx Gaui X5FES,AR7200BX,Xera4020Torq9088,9188 |
#4 | |
Logo 500 VBAR GOV/YGE MSH mini-p VBAR mcpX V2 mikeaarset.zxq.net |
#5 | |
Tarot 450 Pro V2 DFC 6S - Scorpion 2010 - YEP 45A - Hitec 5065 - Hitec 5084 - Robird G31 Trex 500E DFC - Castle Vertigo 1800 - Castle ICE75 - DS510M - DS520 - AR7200BX MSH PRÔTOS - Scorpion 880 - YGE 60A - Futaba 9650 - Futaba 9254 - AR7200BX |
#6 |
just ordered http://www.oringsandmore.com/servlet...h-rings/Detail
now I can build 25 heads! |
