| 4G6 / V120 Series Walkera 4G6 / V120 Series Helicopter Support |
well after a long time i finally have a heli fly...but there seems to be a problem.. i was testing the motor and esc to see wich way the motor should spin and the motor wont spin at all. i can feel it ad hear it that it wants to. i am doing this holding all 3 wires with my fingers separately of course. but after 5 seconds when i throttle up it stops trying to and i can feel the wires and esc getting hot i have to lower the throttle down.the esc that someone sent me was used i think its one of the xp's with red board..is the esc bad????.
the motor its brand new a ta 915 |
It could be that the ESC needs to be programmed to work with your motor, the most important parameter being 'timing'.
Were there any instructions with the ESC that mention programming it? |
#3 | |
i ave xp12a no programing card can it be programmed witout a card.??????? Last edited by raptorddd; 04-25-2012 at 05:12 PM.. |
#4 | |
When you have your TX powered and power up the bird, does the motor beep a few times to let you know it has initialized and is armed? If so, try this: (This works on the XP-7A and likely will work on the 12A but I don't know for sure and again, it depends on how it is wired into the RX) 1). Remove the main rotor blades, in case the motor does spool up during any of this. 2). With the bird unpowered and the TX powered, push the throttle up to maximum. 3). Apply power to the bird. 4). The motor should beep a few times but the sequence of beeps will be different than when the bird is powered up with the throttle is set to minimum. If the above works, it is programmable from the TX but, I don't know how to proceed from there as the XP-12A may be different than the XP-7A. With the XP-7A, it will beep twice to indicate it has set maximum throttle and then if you wait for 6 seconds, it will play a sequence of notes to indicate that it is is programming mode. But, if the throttle is reduced to '0' just after the initial beeps and before the sequence of beeps indicating it is in programming mode, it will then change to operational mode and arm itself. If it goes into programming mode, the motor will then go through a sequence of various beep sequences with each beep sequence indicating a specific field that can be set and lowering the throttle to '0' just after any one of them will put you into a mode where you can adjust the setting of that field. For each field entered, there will again be a sequence of beeps but this time, in a sequence from 1 beep to as many beeps as there are options. Raising the throttle back to maximum just after one of the beep sequences at this point selects whichever option had just beeped. Without knowing what the various fields and options are though, you'd have to guess which is what but if the max-throttle on powering up the bird gives you a different beep sequence from the motor, you can at least know that it can be programmed from the TX and then it is just a matter of finding out what the programming sequence is from there. |
#5 | |
#6 | |
As for how it is wired into the RX, it is more a matter of the combination of where the signal for the ESC comes from and what the ESC does with it. For example, a Plug-n-Play all-in-one ESC that CX2Pilot tried couldn't go into programming mode at all while the one I've been playing with can even though they both get their signal from the RX in the same place. Do you have a link to where the XP-12A that you have can be bought from? I know you bought it from someone other than a retail outlet but if I had something to start tracking down how it is supposed to work, it might help. On the other hand, it might not either. |
#7 |
I ran it off the stock 10a ESC or the stock 20a m120 ESC. I gave this motor to him an worked fine witch was brand new. It worked for me before I sent to him probably the timing on ESC. It might work better direct solder to ESC.
#8 | |
![]() ![]() ![]() ![]() no link to where it was bought it was given to me by VTHELI.. |
#9 | |
#10 | |
#11 |
