Old 01-29-2012, 08:41 AM   #261
razer t-rex
i will need some for hk450 and trex 600 both are stock plastic
t-rex 600 n pro
added a new chopper to the fleet...
hk 450
razer t-rex is offline        Reply With Quote
Old 01-31-2012, 05:16 AM   #262
HEIM JOINT
I have weights designed for the Trex 450 SA plastic grips. If the HK are a copy of that then they would work. If not Then I dont have anything to fit the plastic HK. I have weights fot the T600 plastic grips. PM me with your answer and I can place your order.
Thanks, HJ
HEIM JOINT is offline        Reply With Quote
Old 01-31-2012, 09:20 AM   #263
cpmboy
mine arrived today!...thx Robin. Will install it in my next flight. mine wt flip the grip mod....btw....what suitable tools to work on this screws?..
All begins (Jun 2011).......
Solo Pro V2, Trex 450 Pro, Walkera QR Ladybird,
Blade 450 3D,DJI F450, MCPX V2, WL Toys V911
Next project:
MSH Mini Protos, 450 Airwolf
cpmboy is offline        Reply With Quote
Old 02-09-2012, 03:50 PM   #264
ABQRon
Heim.
I am interested in two sets of weights. Both for a Trex-500, one with plastic T/B grips and one with metal grips. Thanks.
Ron
ABQRon is offline        Reply With Quote
Old 02-11-2012, 10:44 PM   #265
gmoneyhobbit
i would like a set for my trex 550 with metal grips please PM me
gmoneyhobbit is offline        Reply With Quote
Old 03-10-2012, 04:29 AM   #266
iborg
Hi Heim
I would like a set of weights for a CopterX Black Angel.
If you have a suitable set, please let me know.
If you wish, I will take a photo of the tail rotor and post it.
I am just a newbie, but, this seems too good to ignore. I hope to test the current draw before and after fitting.
Have fun!
iborg is offline        Reply With Quote
Old 03-11-2012, 06:20 AM   #267
aeroschlumpf
does anybody know how or where i can get one of those in germany
(for T Rex 500 ESP metal tailgrips)?
Thanx,
Marcus
aeroschlumpf is offline        Reply With Quote
Old 03-11-2012, 09:57 PM   #268
HEIM JOINT
Originally Posted by iborg View Post
Hi Heim
Have fun!
It looks like 450SEV2 weights will work. You can return them if they dont fit.
I will PM you purchase info.
Old 03-15-2012, 07:45 PM   #269
pjuran
Hi Heim,
I would like to purchase the spaces and chinese weights for a T-Rex 250SE. Please PM me.
pjuran is offline        Reply With Quote
Old 03-17-2012, 08:00 PM   #270
Luvmyhelis
Back to order another couple of sets. I blew off one of my 3 blade grips when the grip bolt failed. So I need to reorder that missing one if possible. The package # was for a 450 SeV2. Plus here is an interesting order. I am building a stretch 12s 600 using one of HeliHavens raised tails using one of Bobs three bladed rotors from Rc-Tek. Not sure what you recommend here. This is the link.
http://www.rc-tek.com/us_store/i2rc-tbt56-trex-550-600-high-performance-tri-blade-tail-grip-assembly-p2277.html
Randy
Luvmyhelis is offline        Reply With Quote
Old 03-26-2012, 06:26 AM   #271
HEIM JOINT
Randy
If the thickness of the blade grip at the blade bolt is close to the same as the original Align metal grips, you could use the T600 Align metal weights.
HJ
Old 03-27-2012, 02:43 PM   #272
Luvmyhelis
Ah, good thing I kept a set of upgraded stock style metal grips to measure. Thanks HJ! I should Pm ya shortly with the results.
Old 04-21-2012, 09:01 AM   #273
Kornegay
Would the ones for the 450 work on the beam e4, I would love to order a some if they are compatible.
Kornegay is offline        Reply With Quote
Old 04-21-2012, 09:06 AM   #274
HEIM JOINT
Yes the Trex 450SEV2 weights work on the beam e4
Old 04-25-2012, 06:07 AM   #275
EricD701
PM sent
Fly crash fix repeat
Tarot 450 PRO FBL
mCPX
EricD701 is offline        Reply With Quote
Old 04-25-2012, 07:23 AM   #276
Kubunter
Default Shipping to germany
Hello,
Is shipping to germany possible?
Need a set for my TRex 450 with stock plastic bladeholder.
Thanks a lot,
Regards Kubunter
Kubunter is offline        Reply With Quote
Old 04-25-2012, 02:02 PM   #277
blindside
anyone try this setup for the slop on the mcpx?
blindside is offline        Reply With Quote
Old 04-28-2012, 10:27 AM   #278
lcc014
Hi,
I sent PM to you few days ago for the order of 250 spacer kit, did you receive the PM ?
Thanks,
Ching-Ho Cheng
Hirobo Quark - Aluminium rotor head and swashplate upgrade
T-Rex 450 Pro, zyx-s, T-Rex 250 SE, BeastX, DFC head, Warp 360, Scorpion 1360KV
lcc014 is offline        Reply With Quote
Old 05-01-2012, 08:47 AM   #279
Kornegay
Default recieved
Thank you very much
Old 06-17-2012, 04:40 AM   #280
Jeffcee52
Default Weight Mod for EXI 450 Pro - TT (All Metal Tail)
Dear Heim,
I would like to order a set of the weight mods for my EXI 450 Pro - TT (All Metal Tail) heli. The blade grips are EXI with the humps on them. The tail slider, slider arms, and bellcrank are all Metal from Microheli. Tail blades are KBDD - 61mm & Main blades are CF - 325mm. Will the mod work if the tail grips already have the humps on them? I am running a 401 Gyro w/ a Futaba Metal Gear S9257 Servo. I have done the Finless Tail Grip Flip Mod already. Will your mod stabilize the tail more or is it even necessary for my heli? I am a newbie, so if you could email me some info on how to install the mod, it would be greatly appreciated. Do you have a site or how do I order this? I am finishing my build so I can try and fly before I lose the summer weather.
Thanks for all you & Finless do for the hobby!!!
Hoping to hear from you soon!!!
Jeffcee52 is offline        Reply With Quote
