Go Back   HeliFreak > R/C Helicopter Support > Outrage Fusion 50
Outrage Fusion 50 Outrage Fusion 50 Electric Helicopter Factory Support Forum
Old 04-30-2012, 12:35 PM   #1
the_wuth
Default Torque Tube Shaft Part No.
Could any one advise, what is the part number for a Torque Tube Shaft of F50?
the_wuth is online now        Reply With Quote
Old 04-30-2012, 01:14 PM   #2
mfbs17
http://outragerc.com/r50n315-outrage...4efa30c3502b4e
mfbs17 is online now        Reply With Quote
Old 04-30-2012, 11:00 PM   #3
the_wuth
Thank "mfbs17" for you advised.
I purchased the Torque Tube Shaft part No. R50N315-2, but it can't be insert the tube shaft spline, it very very fit.
So, I try to insert it by hammering and the result as attached photos tube shaft was rip also compare with the old broken one very easy to fit in .....
Please advised what should I do ?
Name:	F50-Tube Shaft-1.jpg
ID:	312867   Click image for larger version
Name:	F50-Tube Shaft-2.jpg
Old 04-30-2012, 11:05 PM   #4
Slyster
There is a new version of the torque tube.... Outrage changed it last year.
The original is no longer available. For the new one you will need to buy the new splines too. I don't remember exactly what they changed but I believe it was the inner diameter of the torque tube. To make it better.
It's not just a hobby... it's a lifestyle!
Outrage Fusion & 550 / Goblin 700 / SK540 / Kontronik / DX8 / Quantum / RJX / 4010 Duo
Pete Team Outrage.
Slyster is offline        Reply With Quote
Old 05-01-2012, 10:45 AM   #5
the_wuth
Thank Slyster
First, I will try to reduce size of splines by sandpaper first.
Old 05-01-2012, 10:57 AM   #6
ke6d
Originally Posted by the_wuth View Post
Thank Slyster
I've done that. You need a metal file to take off the materials from the splines. The original tube has a thin lip which is a weak point because mine was torn up at the screw holes after a while.
Current Fleet: TRex-700/500/450/250 Vbar, Logo 600SE/600/500 VBar, Outrage Fusion 50/G5 VBar/FB, Blade mCPx x 2
ke6d is offline        Reply With Quote
Old 05-01-2012, 11:13 AM   #7
the_wuth
Thank
I will do that.
Old 05-01-2012, 11:51 AM   #8
Wh1teAfr1can
Thank Slyster
be careful cause if its off center you can cause some BAD tail vibrations. prob easier to just buy the correct ones.
Team Kontronik
Team minicopter
Diabolo Kosmik 200, Pyro 750 - 560kv, HC3X, BLS 255/256
Wh1teAfr1can is offline        Reply With Quote
Old 05-01-2012, 02:35 PM   #9
Michaelinpr
Thank Slyster
Like stated be carefull. New part is better.
You could try chucking the part in a drill and sand it lightly. Go bit by bit and make sure you sand evenly along the part you are trying to reduce and also that the part is centered in the drill. A fine file might be easier to get it done.
FUSION 50 FBL, Scorp HKIII-4025-550/Scorp V 130,610's, V Bar/650
GAUI XB5-EXTREME 12s
, Scorp HK-4025-550/CC 80HV, 610's, V Bar/650
AleeS RUSH 750-KDE-700XF-395/YGE160HV, RJX FS0521HV's, IKON/RJX FS0521HV
Michaelinpr is offline        Reply With Quote
Old 05-01-2012, 10:24 PM   #10
the_wuth
Thank Wh1teAfr1can and Michaelinpr for your advised.
I will spend money to close this matter.
