Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > X5
X5 Discussion and support of the Gaui X5
Old 05-01-2012, 03:44 PM   #1
helidude71
Default Lucky me
Today one boom support rod came loose during flight.
Luckily I wasn't inverted and landed without damage.
After close inspection the screw which goes into the CNC clamp came out.
The other side was loose.
One small phillips screw came out a little bit as well.
(The screw that holds the plastic part that goes into the alu rod.)
I put a little CA on all four phillips screws to be safe.
Loctite is curing as we speak.
Still wondering why this happened.
Never seen this on my Align bird. (With *lots* of flights.)
I used loctite on all screws and degreased all parts.
Must be a high vib spot.
T-Rex 500 ESP FBL, Microbeast v3, Scorpion HK-3026-1600, CC ICE 75
TSH Gaui X5 FES, Microbeast v3, S.Bus, DS610s, DS650, YGE 100LV
Futaba T7C
Phoenix R/C v4
helidude71 is offline        Reply With Quote
Old 05-01-2012, 03:54 PM   #2
Colonel Sanders
That same thing happened to mine. Its just a cheap part, I replaced it afterwards with $10.99 TREX 600 boom supports from anything heli. Not as shiney, but alot more sturdy and their an exact fit, no need to move the boom clamp.
Velosity 50 Nitro, 5.3 Fullsize vbar, Rails
X5 FES 5.3 Fullsize vbar, Edge
Futaba T8FG Super
Team Helidirect
Colonel Sanders is offline        Reply With Quote
Old 05-01-2012, 04:03 PM   #3
helidude71
That is a plan.
But why did the screw backed out?
Because the rods are to flimsy and vibe too much?
Futaba T7C
Phoenix R/C v4
Old 05-01-2012, 04:03 PM   #4
crf69
happened to me.
i finished the flight in a hover.
i used red loctie it aint going anywhere.
Buy good stuff then you never have to apologize to yourself for being an idiot....
Stay Inverted My Friends. Ryan Robinson 7hvGob7GauiX5Warp360SYNE5
"How high does it go?" Love that question.....
crf69 is online now        Reply With Quote
Old 05-01-2012, 04:06 PM   #5
newbheliusr
You'd think a 900 dollar heli would have decent parts throughout don't you? It just amazes me how you can spend 400, 500, 900, 1300 dollars and still end up with crap pieces.
newbheliusr is online now        Reply With Quote
Old 05-01-2012, 04:15 PM   #6
helidude71
Sjeezz, I'm not the only one.
Red loctite could also be the way to go.
And yes I do expect almost all the be OK for the money spend.
I even upgraded the boom clamp for the CNC upgrade because the stock plastic one looks like crap to me.
Pfff...
Futaba T7C
Phoenix R/C v4
Old 05-01-2012, 04:49 PM   #7
fusionsx00
My paranoia makes me check the bolts around the tail boom clamps a lot.
I found the ones around the tail boom do get loose , I even replace my lower Jesus bolt after ever 60-70 flights.
Pretty funny since I fly foam planes I've glued together several times, but I don't think those foamys can kill anyone if there was a mishap. And there cheap.
Dx8 mCPX bl v1 hp05s130X
GauiX2FESds11,ds95i beastx
Gaui X5FES,AR7200BX,Xera4020Torq9088,9188
fusionsx00 is offline        Reply With Quote
Old 05-02-2012, 04:50 PM   #8
helidude71
If lots of us have this problem it got to be some design issue.
I'm going to replace them sooner or later with the Align 600's like Colonel Sanders suggested.
Futaba T7C
Phoenix R/C v4
