| LiIon, LiPo, NiCd & NiMh General General Battery Support |
Switching everything to XT60s. Is there a recommendation for what goes where. Female on the battery, or does it matter?
It does matter if you would like to follow convention. The female bullet one goes on sources like batteries. The shrouded one with male bullets goes on devices like speed controls. That way you match the standard use
- Chris To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. heli...info...news...such Helis: TRex 450 Pro - Protos - TRex 550e Stuff: Spektrum DX7 - iCharger 208B - Hyperion G3 |
#3 | |
Note the gender of a connector is determined by the metal bits, not the plastic housing. Xt60s put the FEMALE bullets inside a MALE housing. You want to put that one (in the pic above) on the battery as it is much harder to short than the other end (a bit of metal can short the pins on the male connector more easily).
-DX8 -MSH MiniProtos Stretched, SK720, DS95/DS95i, Hyp 4S 25C 2500mAh -MSH Protos Stretched, Brain, Hyp DS16/BLS251, 6S 3000mAh |
