| LiIon, LiPo, NiCd & NiMh General General Battery Support |
I just got my Icharger 106b+ and I wanted to Check the internal resistance of my mcpx batteries and they read between 80 and 99 ohms and three of the batteries I just received today new and from what I read the ohms should be like 0-10 or something I an using my parallel charging cable to check the ohms would that make the reading wrong for the resistance and if so world that make other things wrong like volts?
IR is tied to many things and capacity it one. Many newer 5000mAh packs ship with IRs of 1-2 range, 2200 packs might be 5-6mohms. Tiny packs like those used on an mcpx should be much higher but I am not sure where they will land. Rough guess should be in the 20-40mohm range.
- Chris To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. heli...info...news...such Helis: TRex 450 Pro - Protos - TRex 550e Stuff: Spektrum DX7 - iCharger 208B - Hyperion G3 |
#3 | |
#4 |
You can not test the IR of a battery with a multimeter. They do make special meters for it but you are better off not worrying about it. Use your charger as you wish but the number really doesn't matter. The only thing that matters is if the battery does what it is suppose to.
#5 | |
#6 | |
Hyperion make some excellent replacements you should consider when you kill the eflight ones.
-DX8 -MSH MiniProtos Stretched, SK720, DS95/DS95i, Hyp 4S 25C 2500mAh -MSH Protos Stretched, Brain, Hyp DS16/BLS251, 6S 3000mAh |
#7 | |
#8 |
For reference, my Hyperion 250s are about 50-60, TPs 240mah are 75-90, Turnigy 300 mah is135.
Greg ______________________________________________ Synergy E7 - Compass 600e - T500 - Trex Pro - mCPX |
