| 600 PRO Class Electric Helicopters 600 PRO Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
What batteries do you guys think is the best? I currently fly Hyperion. I will need more batteries since I moved up to the 600 from the 450 pro. Also have a 500 but this heli uses the same batteries as my 450. As far as I know I will need to be running 12s on the 600 when I build it.
Go Big or Go Home! To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Base Jumping - To instantaneously extract yourself from a sub-optimal situation, often at great risk to your personal safety, professional reputation, or social standing |
Are you looking for good performance from reasonably priced batteries or something that will hold up to insane 3d flying like the pros do?
Trex 600EFL - KDE'd Out - iKon // Nano AMA# 8675309 |
#3 |
Well both really. While practicing some 3D with my 450, don't think I will go to far into it with 3D though. I am leaning more towards scale flying. Will probably even turn my 450 into a scale bird. I am going to start building a 600E Pro with the AS350 body with the works. Lights, cockpit, pilot etc..
#4 |
been using 3300 30c in series , I have a couple of turnigy and 4 sets of sky lipos 30c theyre holding up pretty well to mild 3d after over 100 flights. Get around 5 minutes of flight
Sent from my DROID RAZR using Tapatalk 2
[Trex 450 PRO V2 3GX, Edge] [Trex 500 ESP(DFC) ICE100, 3GX, Edge] [Trex 600 DFC PRO SK-540 ] [Rave ENV Nitro O.S 105-R,Total G,Outrage, Edge SE 713] [Blade 130X] |
#5 |
stock motor 30c is ok 40c is better if your really going to bang it around
if you go with the kde motor I would go no lower than 40c and for banging 50-65c 65c perferable if your wallet can handle it
Trex 600EFL Pro V2 V-Bar ds610 ds650 cc pro bec Scorpion 130a HV KDE 600XF-530 450pro 1860kv(6s) cc50 (4 DS215MG) 10t pinion, Tarot DFC, Ikon TBS Discovery (Quad), naza-gps, 900mhz fpv, gopro2, ET OSD pro, D/L UHF X-8 Wing , D/L UHF Full fpv package |
