| YGE YGE ESC Support and Discussion |
#21 |
He just did, it reads the current settings from the ESC
"If you think you can or you can not you are right" To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Goblin Xera 4530, YGE 160,VBar Trex 700E, YGE 120HV,, Xera 4035/,8917/ VBar Diablo, HJive, 4525 Ultimate,VBar |
#22 |
Hello,
anybody out there with the below mentioned settings? -->Scorpion 4525 LE 520KV on 12S with YGE 160 HV. Regarding your calculation i got 11,55 PWM. So i have to use 12? and what about the timing? Thanks a lot |
#23 | |
I was just about to ask the same question.
Goblin 700 HK 4525-520LE, SK720, Bl 9180, 9188, YGE160HV Goblin 630 Quantum 4135-530, SK720, Bl 9180, 9188, HeliJive 120HV Goblin 500 HK 4020-1350, SK720, Graupner HBS 660-770, YGE120LV, Trex 250, HK 2206-3900,SK720, DS95i YGE16A |
#24 |
@Scotty - i´m afraid we won´t get an answer here
![]() So what about the other settings for the YGE 160 HV with the mentioned 4525 LE? --> Special Functions? --> Act. Freew. Gov. Mode? --> Gov. Mode P-Gain? --> Gov. Mode I-Gain? --> Startup Speed? --> PWM Frequency (supposed to be 12kHz?) ![]() --> Startup Power? Thnaks a lot for Tips ![]() |
#25 | |
I think that most will generally round down, therefore 10PWM
Dany Synergy E5 in the works Furion 6 Flybarless, Skookum 720 To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Beam E4(v1) FBL, Skookum 540 |
#26 |
Fantastic information! And thank you for the time it took and consideration for posting this up. I was in the setup stage with mine on a new 12s 600 stretch with the esc just hooked up to my motor without pinion. And I hate to say this but the instructions in several areas are weak. But with this info and by directly powering my Yge with the bec instead of directly linking it through the RX, (which gave me nothing, the esc wouldn't take card commands until I did this) I soon had my new esc programmed and the motor spun up perfectly.
I did reconnect the RX when programming the Rpm settings but left the card powered from the bec. I am running the scorp 4035-630. And the timing issue had bothered me as I already run scorp 2221-2010s on my 6s stretches and the factory timing issue there was way off. Plus I have two new 12s prototype motors coming for my 450s and the above info covers almost everything. Many thanks! Btw: I see you had issues with the CCpro HV bec's? Mine run perfectly. What happened? |
#27 |
I think I just found out why my Scorpion running at 150 deg. I'm going to change the timing to 18 and see if it helps.
#28 | |
For that and every other scorpion : Pwm10 Timing 18
Logo 600 - PD-Scorpion 4225 470kv+vbar gov/YGE120hv/Voodoo 600 -PD-MX700-470kv--BLS255hv-VBAR 5.3+ Hobbymaniac Teampilot |
