| MA Glow Miniature Aircraft Glow Helicopter Support Forum |
#41 |
For the Servo horn, either the big Futaba Servo wheels or the futaba heavy duty "T" car servo horns work well.
You'll have to trim down the wheel or cut off one arm on the T shaped one, but this is easy to do with a dremel. Both servo horns are nice and thick. The V-Bar handles a 2S LiPo no problem.
Team Miniature Aircraft USA Team HeliWholesaler, Team Byron Fuel's, Team Thunder Power, Team Scorpion -Darrick |
#42 |
Hey guys,
I was working on the clutch assembly today, and i came to a problem. My hex adaptor ( Part # 128-118) wont fit onto the start shaft ( Part # 128-109). Im 100% sure everything is in correct position, but nomatter how hard i push, i even tried using WD40, the start shaft wont fit all the way on. Also, is the steel shim washer ( Part #0273) that is used on this assembly pre-assembled? I looked everywhere and i couldnt find one in the kit, but when i put the clutch drive bearing block on, it seemed as if there was a washer inbetween them? --Brian |
#43 |
You mean the female hex piece that accepts the shaft of your starter? Check for burs on the shaft and inside the starter piece.
Scott, GySgt USMC Fort Worth Thunderbirds Radio Control Association MA Fury 55 FBL, JR Vibe 50 FBL, T-Rex 550 3GX V2 FBL, Raptor 30v2
#44 |
Hey Semper!
Which bird do you like better? Your JR VIBE, or your FURY 55?? I know one is a TT tail and the other has a belt driven tail, and thats about all I know so far. |
#45 |
The Fury. Mainly because it has a new OS 55 and has more power. My vibe is the older model with an align 50. I bought the vibe used. I do like the vibe though!
#46 |
Hey guys,
i got the O.S .50 SX-H Hyper and CYE Mp5 50 SB installed without problems. Im 99% sure im going with the Outrage servos on cyclic and rudder, running at 7.4V. For the throttle, i want to go with a budget servo, maybe a DS610? Im not too sure for the throttle servo, but if its a budget servo, i doubt im going to be able to run it at 7.4V, but again, im trying to save money and i dont want to buy an expensive, bulky regulator. So i was looking around, and has anyone used a Stepdown Pro from perfectregulators? It seems pretty simple, and the price isnt too bad on it. http://www.perfectregulators.com/ind...&product_id=53 Ill post pics of the bird tommorow --Brian |
#47 |
I would like to give a huge thanks to everyone here who helped me with my first heli. I had a little trouble the first few hovers (Vbar tuning, Engine tuning, etc.) But a few of my friends who fly not too far from me gave me some help. Here is my ~15th flight, I don't have the cyclic at the pitch i want, nor the speed, but for now, im just enjoying every minute of this bird. It flies like its on rails with the Vbar 5.3. Still need to get the pro software to get the gov. running, increase the cyclic agility, and "fine tune" the swash plate. Awesome Bird MA! Thanks again to all the people who helped me!
--Brian
FURY 55| OS .50 SX-H HYPER | CYE MP5 SB | DS 610 @7.4V | BL9188 @7.4V | EDGE BLADES | VBAR |
