| 250 Class Electric Helicopters 250 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
Is there any brand of ball link piler out there for 250 ? I have the Align one (tweezer like) and always mrr the plastic ball link end. The cut out of the Align 250 piler was too wide!!
Thanks,
Ching-Ho Cheng Hirobo Quark - Aluminium rotor head and swashplate upgrade T-Rex 450 Pro, zyx-s, T-Rex 250 SE, BeastX, DFC head, Warp 360, Scorpion 1360KV |
I just used some pliers to squeeze the gap closer.
Align TREX 450 Pro V2 3GX Align TREX 250 Pro 3GX Blade 130X, mCP X BL, mCP X V2, mSR X, 120 SR, mSR, MCX2 DX8 |
#3 |
Okay, I will give it a try.
Thanks,
#4 |
Admittedly this is un-helpful, but...
I think it is shameful that Align has not created a tool that works well to separate the ball links on the 250. That ridiculous tweezer thing sucks a** to say the least. And I am surprised that one of the other many firms that fabricate tools like that have not filled that void. There are probably nine different ball link pliers in existence for machines-larger-than-a-250, but I haven't seen ANY that'll work on the 250. ![]() |
#5 | |
#6 |
Search for FS1212 for the correct ball link pliers.
YMMV, Don |
#7 |
Could not find any piler, just filter !!! Are you sure this is the correct part number ?
#8 |
http://www.experiencerc.com/store/fl...12-p-7463.html
do a look on google .. with FS1212 ball link .. tons of pages
B400 gotta love the old girl / 250 / 500 .. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Turn Up The Juice. See What Shakes Lose |
#9 |
Nice! Leave it the Freaks to step up when the need arises!
Does anyone own this exact tool? I've been burned before when buying a tool that is supposedly suitbale for XX application...only to discover tha it really isn't any better than all the rest. Thanks! |
#10 |
I use the align tool that comes with the combo. I realise there is a certain technique in using it.
#11 | |
Thanks,
#12 | |
Thanks,
#13 | |
Don |
#14 | |
#15 | |
I ordered the tool suggested by Don's. Hopefully it will arrive soon from UK.
#16 | |
Thanks, I ordered one from that website.
#17 |
I have one coming too. We'll see. I'd be a campy hamper if it worked out; I'm frustrated with the force required to disengage these [fairly dainty] ball links!
#18 |
Absolutely correct, need tremendous force to remove the link from metal ball. This is even worst when doing the link end removal at some awkward position !!
#19 |
I received the piler today and I measured the width of the fork. It is about 3mm. I measured the metal ball used in 250 last week, it was also 3mm width. Align tweezer like piler was about 4mm in width. So, I am pretty sure that this piler will work nicely. I will give it a try tonight.
#20 |
The only trick using the pliers is don't squeeze too tight. Only medium pressure is required if the pliers are lined up properly. If you get them not right then too much force is required and you can damage the pliers. They work really slick once you learn how they need to be lined up.
Don |
