| Blade 400 Blade Helicopters (eFlite) 400 Helicopters |
My hobby shop is out of blade 400 main gears.Will any other brand fit the Blade 400?, such as Esky or Align?
Esky King 3 main gear should work. I've used a B400 main gear on the Esky K3 before. Don't see why it wouldn't work the other way around. But good luck finding Esky at a LHS.
Trex 500-3226-1600, 13T, Koby 90LV, HS-5245MG, DS520, AR7200BX, DFC Trex 450 Sport-450M, 14T, RCE-BL35X, HS-5065MG, HSG-5084MG, AR7200BX, DFC DX8 |
#3 |
It does not look much like a Trex gear. I would just order one form Helidirect or the such. Throw in a few spare parts to make it worth shipping. You will have your new parts in a week. I like having some spare parts on hand anyway.
Gaui Hurricane 425 FBL with Robird G31 500 Class Rocks! To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. EFlight Blade 450 3D, Walkera Super CP Walkera Devo 10 w/ Deviation |
#4 |
i beleive the blade 450 main gear fits but check out the blade 400 sub forum
http://www.helifreak.com/forumdisplay.php?f=98
MCX2 , MSR , MSRx , 120SR , MCPX v1 , MCPx v2 , Blade 400 3D , DX8 To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#5 |
Yes, the B450 gear will fit, but you also need its new center hub to pull it off. You are stuck here as far as I know. Either pick up new B400 gears or upgrade to the microheli version. Which is superior in a half dozen different ways btw.
#6 |
I use a blade 400 main gear on my esky belt cpx. It has the same tooth count, and is a direct fit for the esky. Maybe it will work the other way around. Be aware though, the esky main gear is replaced by many for a reason: it strips very easily.
// T-Rex 600EFL Pro 3GX // T-Rex 450 Pro V2 3GX // T-Rex 250 Pro DFC 3GX // // Walkera V120D02-S (x2) // Walkera V120D02 // Walkera Genius CP (x3) // // EFlite Blade MCPX (x2) // EFlite Blade 120SR // E-Sky Belt CPX // // WK2801 // Spektrum DX4e // |
#7 |
Yeah, but has anyone ever seen a local HS that carries Esky parts? Not me.
#8 |
I'll send you a PM about B400 main gears I have, might help.
Mike
#9 |
How does one go about installing the one way bearing into the main gear? Lub,heat, whats the trick?
#10 |
What heli? On the trex 450s it is a press fit..A small vice works well..
700 class nitro,2X 600class electric,2X 450class,250 class,130 class,a few mcpx class( To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. ).Dx-7.All helis fbl...If I had a dollar for every dollar I've spent on heli's ...I would break even. .Who is John Galt? |
#11 |
This tool, and a bench vice will remove,and install one way bearings. ,http://helidirect.com/align-one-way-...elis-p-408.hdx
So will the correct size sockets.
Raptor 50 OS50 Hyper, Futaba 520 Miniature Aircraft Furion 450, Spartan Quark Futaba 9CHP |
#12 |
A little hard to explain. Place the main gear in the bench vice. Use the appropriate
driver/socket to press the outer race of the bearing into a receiver socket/tool of slightly larger diameter. This is the same procedure for most one way bearings.
#13 |
Installation is the same, except no drivers are needed. Simply press the OWB into the
gear until flush.
#14 |
Here is what I came up with to change out the OWB on my Outrage 550. When you learn to fly CP helis with a Belt CP you learn a couple of tricks. This will work for any heli, just need to size the pieces correctly. About 10 minutes in a home improvement store with the center hub and I was ready to go.
http://www.helifreak.com/showthread.php?t=334104
Paul Outrage 550 - Castle 3434-1100, Ice 100, Bec Pro, 94758z, Total G w/JR 8900G Outrage 550 - 4020-1390, Ice 100, Bec Pro, JR 8717s, Total G w/JR 8900G Rave Ballistic FSO - HKIII 4035-560, Ice HV160, Bec Pro, JR 8717s, Total G w/BL-9188 |
#15 |
put your heli(s) in your signature. It just makes life easier for everyone
It's not just a hobby... it's a lifestyle! Outrage Fusion & 550 / Goblin 700 / SK540 / Kontronik / DX8 / Quantum / RJX / 4010 Duo Pete Team Outrage. |
#16 |
Thanks everyone.
Blade 450 heli,Mks 92'scyclic, Eflite g210 gyro,ds76t, Dx6i |
#17 |
I installed a new main gear on my blade 400.All was well, gear mesh was perfect, so I took her out and within 1 min. I noticed heli was acting funny.It was like the main gear and tail gear fused together.I cuold not manually spin main or tail gear and after a few minutes of trying they let go and spun normally.So I put motor back on and went to fly again and same thing happened.Any ideas? I have rebuilt heli quite a few times and gear is not upside down or anything else like that.Maybe a bad one way bearing?I'm stumped.
#18 |
Sounds like a one way bearing to me.
#19 |
I bought a new main gear with one way bearing for my blade 400.I could tell something wasn't right and it appears the oneway bearing isn't seated properly and therefore it is not spinning true.Is it possible to fix this or should I return it to place of purchase?
#20 |
I'd say return it.
I am not familiar with that maingear setup, but the one-way bearing is pretty sensitive to how it is mounted in the hub. In other words, you can damage the one-way if you over compress it in getting it into the hub. At least I was able to damage mine when I tried to get a new one into an Align 250 SE hub . I just buy the entire setup now! |
