| 450 Class Electric Helicopters 450 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
Hi
My heli is a 450 FBL V2 with 3GX with: stock motor 3400kv, stock 15T pinion and stock blades. I reach 10 min with 2200mah, only hovering and FF, scale flight. If I replace the 15T pinion for a 13T pinion. So the HS will decrease. Could I increase the flight time? Maybe 12 min? Thanks |
Unless you are throttling back a lot on the throttle curve, your headspeed will be high;
3400 x 11.1 x 0.9 x 15T / 150T = 3400rpm at 100% At this headspeed (or even close to this) for 10 minutes you may be running the 2200mAh lipos very flat, and if so, you may be damaging them badly. I run 2500rpm, and get 8 minutes on about 1500mAh, so if I ran for 10 minutes, I would be exceeding the 80% of capacity. Rather get more lipos than kill yours by over-discharging. But yes, a lower headspeed would certainly allow longer flights. Colin
Vario Long Ranger 700e Seahawk 600 - work in progress Atom 500 Trex 450 SA hybrid |
#3 |
Colin, thanks for your reply.
So with 13T... 3400 x 11.1 x 0.9 x 13T / 150T = ~2950rpm at 100% = less HS = less power? no longer flights? And how do you run with 2500rpm? Thanks, Marco |
#4 |
just recently I replace my 450M with 450MX. My old 450M fused with 14T and now my new 450MX with 15T. I hvnt took it 4 flying yet but on the bench it felt powerfull compare to 450M + 14T and I afraid that the stock ESC cant coup with it. I was thinking of just make do for a while with 450MX + 14T.......hovering and just into FF........
All begins (Jun 2011)....... Solo Pro V2, Trex 450 Pro, Walkera QR Ladybird, Blade 450 3D,DJI F450, MCPX V2, WL Toys V911 Next project: MSH Mini Protos, 450 Airwolf |
#5 | |
Colin
#6 | |
Trex 450 Pro V2 FB spartan quark trex 250 beastx Fusion 50 beastX |
#7 | |
I typically put back about 180mAh per minute, so 10 minutes would be 1800mAh (just checked my logs), which is 81.8%, so if I dropped from 2500rpm to 2450rpm, I would probably be below 80%. My guess is that with the headspeed the OP was likely to be running, he would be getting close to 100% though, which certainly would be killing the lipos (as said in post #2) Colin
