| 700 Class Nitro Helicopters 700 Class Nitro Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
Hi, on my T-REX 700N 3G, What are the correct settings for the mixing base assembly collar in terms of hight and the allignment? As per the manual, it says the space between the main rotor housing base and the collar should be around 10.8mm and the collar should be horizontally vertical. If I go for this config, on full pitch 13 and full ALE and ELE around 12, the ball link on the swash binds with the screw of the mixing base collar. How can I avoid this? Should I move the collar a little on right but the rods coming in from the main blade grips won't be 90 degree. Would this change the flight characteristics?
Thanks. |
Are the swash driver arms horizontal at 0° collective?
If you have the shorter main shaft, the swash driver will be pretty much butted up against the bottom of the rotor hub. If you offset the swash driver your rotorhead phasing will be incorrect causing aileron/elevator interaction - so no you can't do that. If you post a picture of the rotor head at 0° collective it may help to see what you have done wrong.
T-rex 700n VBar 5.3 Pro | T-rex 700e V3 VBar 5.3 Pro To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. | JR DSX9 Limited Team RCBits | Team Lynx |
#3 | ||
, the 3G setup was with the original 700N long shaft, if you're using the FBL main, then the distance between the mixing arms and the head housing is 2mm. . What ever you do, do not offset the swash driver. Pictures of the head at 0 pitch, full up and full down would help, include the swash and bellcranks in the pics. ![]()
At the precipice, we change! To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Team GrandRC |
| Tags |
| trex 700 3d trex |
