| SAB Heli Division 630/700/770 SAB Heli Division 630/700/770 - Goblin Helicopters Factory Support |
I'm just wondering if there's anyone with HeliCommand HC3-Xtreme or HC3-SX on his Goblin out there?
I'm playing with it but can't tune the elevator. Tail and aileron works absolutelly great but elevator bounces and bounces no matter what I set. It's obvious I do something wrong but what? I've set many helicopters with this system very successfully but Goblin isn't following ![]() My Goblin has 6 flights so far so it might need to break in a little bit more? |
Both Goblins I've seen maiden had elevator bobbles for the first couple of flights. It should wear in, but if not check the elevator linkage and see how tight the ball links are.
Team RotorQuest / SAB Heli Canada SAB Goblin 700 YGE160HV, Goblin 770 YGE160HV Scorpion 4530 14s, Goblin 500 YGE120, Logo 700 XXtreme, Protos Mini stretch 6s |
#3 |
Im using the HC3SX on my Goblin and did have to do a bit of experimenting with the elevator settings.
Probably the relatively high mass of the tail that can cause problems for the elevator channel. Best thing is to assign the real-time tuning to a knob on the RX and work on it from there.
Goblin 700 "Sabrina" Scorpion, HC3-SX Trex 600 EFL "Tracy" Castle BBQ, HC3-SX Yes, they have names. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#4 |
I'm at flight no. 10 at the moment and found that all gets better as it wears in probably.
I think you are right with the heavy boom. Normaly on any other helicopter it was just rise the D gain up to 16 and it was it. Maybe in some cases use elevator filter at 1 and done. On the Goblin I'm at D gain at 17 and elevator filter 2, P 30 and it's slightly better. Still tuning it in real time and I'm getting closer and closer. What's your findings so far? I'll post my file from HC3-SX once I got to the heli. |
