Old 05-08-2012, 12:24 AM   #1
Stealthpilot
Default Metal Main Shaft Bearing Blocks
Does anyone know what the difference is between the Align bearing blocks part number H45027 and H45027A? To me they look exactly the same? Thanks in advance.
Randy
TRex 600 Nitro Pro, TRex 450 pro
Boeing CH-47F NETT SI
Stealthpilot is offline        Reply With Quote
Old 05-08-2012, 02:19 AM   #2
trexpro
These are the specifications of Align
Metal Main Shaft Bearing Block H45027A
●Use for T-REX 450 Pro / 450 Pro 3GX.
●6061-T6 Aluminum alloy material and CNC processed.
●Metal bearing holder x 1
●Bearing 685ZZ x 1(Φ5xΦ11x5mm)
●Socket button head screw x 4(M2.5x5mm)
●Weight:20.8g
●Use for T-REX 450 Pro.
We Men Need a Second Hobby, Besides Women
Futaba, Vbar, Kontronik, Align, IKON, 3GX, Vario, WR Hercules
Mikado, Scorpion, BeastX, Gens Ace, Goblin, Hyperion, JetCat Turbine, APS, BD3SX
www.modelhelicopter-review.nl
trexpro is offline        Reply With Quote
Old 05-08-2012, 01:38 PM   #3
dave21740
I need to replace mine, so I was looking into this last night. I asked customer support at amainhobbies.com about the difference between the H45027 and H45027A parts, and their heli guy didn't know. That's a little odd, since they price the two parts differently (the A version is lower priced). If I had asked someone in sales/marketing I might have got a different answer than I got from tech support.
Some vendors charge the same for the two parts.
Align came out with the H45027 in 2009 and the H45027A in 2011, and their retail price is the same for both. I've asked Align about it through their contact link, and if I hear back I'll report what they say, if nobody has found the answer by then. I'll probably go with Amainhobbies, since their price for the more recent A version is lower than I've found elsewhere.
mSRx / nCPx /mCPx BL / 130X / mQX / 350QX
Trex 450 Pro AR7200BX / Trex 500 Pro DFC AR7200BX / Trex 600e Pro DFC SK540
DX8/9
What is with this compulsion to put "X" in product names?
dave21740 is offline        Reply With Quote
Old 05-08-2012, 04:21 PM   #4
Stealthpilot
If I had to guess, it would seem that the A version is made of a different grade of aluminum??? Why else would they specifiy "6061-T6 Aluminum alloy material and CNC processed" I would think everything else "spec wise" would have to be the same, otherwise it would not fit a V1 Pro/ 3G Pro???
Just guessing here, thanks for the info guys!
Randy
Old 05-08-2012, 05:04 PM   #5
dave21740
I agree with you, speculation or not And I expect that's the answer I'll get, if anyone I wrote to replies.
DX8/9
Old 05-08-2012, 08:40 PM   #6
dave21740
The answer from Align:
"H45027AT is CNC processed"
I suppose the aluminum alloy might be different also, since they mention it by name in the A version description. But, in any case, CNC is at least one of the differences.
A Main Hobbies has H45027A for $12.75, as opposed to $13.99 for H45027, so I'm grabbing 2 of them and getting my heli back in the air
DX8/9
