| 250 Class Electric Helicopters 250 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
I was setting up my Align TREX 250 servos and they were working fine, but then I set my pitch curves to level the swash and accidently reconnected to the Spectrum ar6115 with the throttle at 50% (on my DX6i)and the servos just "chatter" and the receiver just blinks the red "hold" led.......I've tried to rebind but the receiver just won't "talk" to the servos any more, I even replaced the receiver but the same thing happens. I don't think that I changed any other settings on the DX6i so I don't know what else check/replace. |
Have u tried just esc, rx and binding it?
Yes I miss the odd screw, so what To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Trex 700N Vbar, Mikado LOGO 600SX, Trex 450 SportV2, Trex 250se-dfc, MCPX ...DX8... |
#3 |
Rebind to a clean model, or put your pitch curve back to a linear 0 -> 100
It's probably your curve or swash mix that you said you changed to level the swash. If you haven't finished your swash mix then you won't get any movement on aile or elev. I always bind at mid-stick with TH on so if the signal drops and goes to failsafe, it's set at 0 pitch (not -12 ) and a recoverable throttle value (about 15%).
TRex 250 DFC | TRex 250 DFC (Scale) 2 @ TRex 450 DFC | TRex 450 Pro 3G (Scale) TRex 550 DFC DX8 + Telemetery on all |
#4 |
I took a guess that it might be the ESC due to the fact that there didn't seem to be any power getting to the servos, got a replacement yesterday and everything seems to be working fine, thanks for the replies.
